Kelisa jerking during jam
11000RPM
954
2
3,018
Johor Bahru
Dear sifus,
Anyone can share your experience on jerking problem for kelisa during jam?
The car will start to jerk and even die off after jam for 15 - 20 minutes.
Can any sifu enlighten me?
Thank you.
Supra_Fanatics
20,673
3,998
idling rpm low?
Does the air con lose it's coldness?
If no - clean the throttle body. Probably has carbon stuck there keeping the TB butterfly slightly open when it's supposed to be closed.
If yes - you have some other problem. Need further investigation.
Supra_Fanatics
20,673
3,998
Ah Shit, that day should have clean the TB also haha!
11000RPM
954
2
3,018
Johor Bahru
Yes bro, air cond is cold. :(
The last time I check, the tb is dirty. Cleaned but after 2-3 weeks comes again.
The the 2nd time I check, they overhauled my block, changed new rings etc etc.
2 - 3 weeks, comes again.
I can't remember if the Kelisa has a sensor (MAP/MAF). Perhaps it's a sensor problem? Did anyone use a scanner to check for fault codes?
I just thought of something else, perhaps your TB itself is the problem. The stepper motor inside is broken but not entirely broken? That's why sometimes it happens?
Supra_Fanatics
20,673
3,998
Got MAF sensor.
11000rpm of course lo. Rev so high all the time. :rofl:
If really got 11K RPM, then I think I will be the one waiting for u guys last Sunday :rofl:
Hello.......to all modification 'otai'2 & Drag GodFather:adore:..........
I really need your advise/help for recommend me to which shop/garrage that expert modified BREMBO 4POT front & BREMBO 2POT rear to my WAJA :hmmmm:.... More preferred any garrage located at northern side such as Perak,Penang,Kedah,Perlis if not any expert garrage also can. :D Really need help.....! Any advise,guided,foreman charge,costing are very welcome.......Thank you very much..... ! :wavey:
Maju Lah Sukan...
