fuel regulator
satria_95
6,746
18
5,138
Malaysia
What's a diaphragm? *scratch head*
From what I read in this thread, it seems that fuel pressure regulators benefits almost all fuel injected cars. I'm running a satria 1.6L manual tranny with just a k&n air filter. I saw the arospeed ones (see link below).
Click on picture for details.
AROSPEED ADJUSTABLE FUEL REGULATOR --TANK
Aro Speed Fuel Gauge - Carbon Face
Fuel Regulator Gauge -- 100PSI
Arospeed Adjustable Fuel Regulator
I was wondering about something. Some have mentioned in-car fuel pressure meter. Is it one of the products above? Or is there another separate meter to be installed in the car?
GT_AUTO
3,503
71
1,648
K.Trg
www.facebook.com
oh cannot too high ? the pressure how much ? original how much ?
yup.if i'm not mistaken,the ori press is around 22-28psi.32 psi should be
enough for ur car.too high n ur car will be sluggish due to too much fuel been
injected into u engine.
diaphragm is a piece of rubber found inside the fpr.it benefit ur engine by
spraying a more even fuel so the spark plug can burn more complete.making
a bigger explosion inside the combustion chamber thus increasing ur engine power.
no,it's not bro.the pic that u see is the meter that attach to the fpr itself.
to install a meter inside the cockpit,u need to buy meter like defi,apex'i or
those taiwan meter that read fuel pressure.
satria_95
6,746
18
5,138
Malaysia
gt auto,
oh, like that ar. erm.... well, I think I'm going to install e-manage before all else la. hehe Heard that e-manage is a good investment and can help obtain some easy bhp's too. hehe I won't be expecting much from it, though. 10% also happy already. hehehe
boeytan
736
i bought an apexi neo n going to Dyno it soon. Do i need a fuel regulator? My car is waja.
Northiswara
2,589
7
fuel regulator.
heard can give good performance to ur car. for NA canot expect so much improvement but for turbo it is damm sweet.
my 2 cents opinion.
blugu
11
I have problem with my FPR, my engine is 4G92P, with harder valvesping & P&P head modification, currently my FPR default reading is ard 50psi, im using 2nd hand arospeed FPR and im using honda civic (denso) fuel pump, are my reading reading normal or the FPR diaphragm broken or damage due to leaking or something??
p/s: if i tighten it, it can only compress to max 52psi & if i loosen it, the indicator pressure also shown decrease less than28psi, the question is...
1. Fuel pump problem or
2. FPR diaphragm problem?
3. Where can i find the Arospeed diaphragm kit?
Thanks in advance...
Northiswara
2,589
7
this situation is tough. no idea.
maybe the meter rosak juga.
Maxx
2,072
42
5,148
PD-Putrajaya-KL
www.zerotohundred.com
might be ur fuel pump cannot put out more pressure than 50psi.
i think aerospeed afpr cannot changed the diaphragm. as u can see, it uses rivet instead of bolt and nut.
Dear sifus,
I really need some advice on what to do here. I'm currently driving a 1.5 Wira 2001, currently has done 86,000km. Problem is that the engine seems to be consuming engine oil. My last service is only like 3,500km and the level from the dip stick has shown a drop of half level i.e. Original=3/4 of dip stick; Now = 1/4 of Dip Stick. My exhaust doesn't show any smoke to indicate oil consumption even if the engine was revved at stationary (funny though).
My mechanic told me to do a...
