fuel regulator
zakie
131
fuel regulator??
hmm... its completed if combination goes like this...
fuel catch tank + external fuel pump + fuel regulator + upgraded fuel rail + upgraded fuel injection.... confirm smooth...... :thefinger:
wasteg4te
154
9
jb
ok maybe next year.
my car will complete with those items.
heheeh hopefully
Gobbi_21
173
All sifu .... im currently using 4g91 carb .. all standard ..
im totally new to fuel regulator or fuel pressure regulator ..
im totally confused which to install for my engine ..
i need the best suggestion on the brand and what is the differences of FP & FRP....
going to fix soon to have a better fuel consumption and better driving ..
hope to get the best info
thanks sifu
Bump: All sifu .... im currently using 4g91 carb .. all standard ..
thanks sifu
Wira_lover
341
thanks sifu
thanks sifu
Bro,
Previous Sifu have explained i think on the 2nd page that a carb engine will be pointless using a FPR...insuffiecient pressure.Another thing is also carb engines split the supply of petrol to 4 different runners then into the combustion chamber.Fuel injection cars inject/spray the supply directly into the combustion chamber.
From previous threads ive read,for carb cars,better to upgrade to Walbro fuel pump.Other than that im honestly not so sure i too am only a newbie and i dono much about carbs.
Another thing,if youre looking to save petrol....then you are in a difficult position.Cause only your right foot can save you fuel and also patience.Performance needs fuel.
SkYwAlKeR
Over 10,000 RPM!
10,139
300
5,183
ePoh ~ malacca
Bro,
for carburetors, it is not recommended to use high pressure fuel pump... hence, increasing ur fuel pressure for carburetor engines is a bad thing... u will flood ur carb as carburetor fuel delivery is through a float inside the carburetor body... (imagine having a toilet flush system inside ur carb)... valve will close when the float reachs a certain level... if u have high pressure fuel pump, it will force open the valve and floods the carburetor...
hence, carburetor engine best to use high flow fuel pumps... CARTER is one of recommended high flow fuel pumps, works best with weber/solex or other performance carburetors....
walbro fuel pump also high pressure... so, not recommended for carburetor engines...
Wira_lover
341
ohhh, yeah now i get it. Last time i had a Saga Knigt,4g15 carb.now i remember how it applies.Thanks sky.
frank118
435
24
yes...sky is on the dot...also changing fuel rail is important to handle the pressure.
tofu_manic
1,342
91
5,148
actually for those running external fuel pumps for the carburettors, they do have fuel regulators which are meant for use just for carbs, but uncommon...dunneed lah....better put the money elsewhere
Bump: actually for those running external fuel pumps for the carburettors, they do have fuel regulators which are meant for use just for carbs, but uncommon...dunneed lah....better put the money elsewhere
slipar
500
61
banting - pj
tumpang tanya to sifu here..
running 1.8mivec with standard 4g93 injector..
what the press needed in idle & also wot..
AD_EG
6,000 RPM
6,328
231
Ipoh
1.8 Mivec 38-42PSI on idle...WOT i think should be around 46psi...
Hello Forumers,
Where can i find in malaysia the following waxes
Collinite 476S
FK 1000p
thanking you in advance for your cooperation
