fuel regulator
blugu
11
might be ur fuel pump cannot put out more pressure than 50psi.
i think aerospeed afpr cannot changed the diaphragm. as u can see, it uses rivet instead of bolt and nut.
ya, maybe the my fuel pump is the main problem, i will try to add relay to my fuel pump & see what happen next :hmmmm:
Northiswara
2,589
7
u know the wiring? dun connect wrong wire later teruk.
blugu
11
no need to worry sir, I just ask my wireman who do the wiring at the first place, thanks for the reminder
Northiswara
2,589
7
got wireman. good lar.
later salah wire vtec canot open. haha.........
Maxx
2,072
42
5,148
PD-Putrajaya-KL
www.zerotohundred.com
that might give better voltage to ur pump.
might be u wanna check the voltage drop at ur fuel pump while running 1st.
rewiring dedicated cable for pump (bigger/better cable) + relay will help deliver most of ur pump performance.
GT_AUTO
3,503
71
1,648
K.Trg
www.facebook.com
i think u max out ur fuel pump press already bro.that normal for a stock
civic fuel pump.my 2 cent.
pyccce
240
5
wat is the idea for L502 wit td025 turbine?Tq
D-IV
262
err.
what will happen when i install powerfull fuel pump such as walbro, but no fuel regulator.
is it any problems can happen?
and another things with is better
walbro fuel pump
bosch, or sard for sr20det (stock engine)
Depends on what flow of pump you're using. If you're using the 190LPH walbro, you might be lucky to run better than the 255LPH walbro without the regulator. Running too big of a fuel pump without a fuel regulator means you are creating high pressure at the fuel rails, increasing the amount of fuel injected per opening. So running unnecessarily rich at idle too.
IMO, big fuel pump should be accompanied with A-FPR and a fuel management system. Anyway, increasing fuel pressure does not create a bigger explosion in the combustion chamber leading to power. Fuel Injectors has their working pressure, exceeding the working pressure makes it less efficient in their spray patterns. Instead of giving a good one, its jetting out a straight one..thats where you need to find a higher cc injector to feed your engine needs. Wide spray patterns increasing burning efficiency leading to power and not better explosion (detonation).:biggrin:
wasteg4te
154
9
jb
D-IV..
thank bro.
it really happen to me.
im using 2 fuel pump. without fuel regulator
then my return hose got some dust. (stuck)
so increase the pressure for injector.
engine running rich.
no power
aisehhh my new denso ir spark plug kong already.
need to buy new.
lucky no major prob.
i'll take note this
D-IV
262
What i commented is about using 255LPH with stock FPR. Regardless whether the line is connected or disconnected. The fuel pressure would still be high regardless.
NAZA Quest (Chevrolet Malaysia) Sdn Bhd announced just established a new business partnership with Indonesian tyre manufacturer; PT Multistrada, to supply the world-renown Achilles tyres to new production models of the Chevrolet Cruze LT Sport. This announcement was made in conjunction with the Achilles Formula Drift Malaysia 2012, where Chevrolet was the official car...
