VTEC turbo
civic9696 & EG6SiRT?, thanks for your info..
as for now,i will not go beyond 7500rpm...just wondering,with this setup roughly how much bhp my d15b can get??
bro, this question is very subjective and i am not able to answer!! it all depends on tuning and parts and also how much boost you re running. may Bro jep3003 can assist giving estimated figure...
bro ulat50, like wat sifu EG6SiRT? said its very subjective... estimated plus minus 200hp depends on ur tuning... ur valvespring n retainers r rated for da cams so unless u upgrade 2 higher duration cams, u dun ave 2 chnge dem... better upgrade your bottom end, ignition, airflow n airtemp too get more hp...
eh..
i thought BANTAI 2.5 bar then okie...
Bump: eh..
Anybody got any experience on Turbosmart Eboost2 boost controller? Any recommended installer which have experienced on this BC before. Any help and review would be helpfull! thanks
Bump: Anybody got any experience on Turbosmart Eboost2 boost controller? Any recommended installer which have experienced on this BC before. Any help and review would be helpfull! thanks
better make sure your bottom end can take it....
what modification require for this?
last week i notice my radiator water always on low level, i check & found no leaking. im not satisfied then while the engine idling i remove the water reservoir/spare tank cover.and found bubbles continously coming out from the water hose...
have u all experience this kind of problem before??
1. check your compression on each cylinder and whether is there a drop on compression in certain cylinder.
2. Might be your head gasket have give up on u.
Bump: 1. check your compression on each cylinder and whether is there a drop on compression in certain cylinder.
vtec turbo...
good stuff...
nice to play..very powerfull..
Bump: vtec turbo...
good stuff...
4 bar = 56psi... whooaaaaaaa... = 1000whp!!
project undergoing ? or in tuning progress?
cant wait to see malaysian honda scene on 1000whp!! Im all up to support it!! yehaa..
my honda no vtec but got turbo wo... can join?:rofl:
Bump: my honda no vtec but got turbo wo... can join?:rofl:
any forced induction honda welcomed!! :smokin:
same family, same interest....d15 turbo?
Bump: any forced induction honda welcomed!! :smokin:
D16 homemade? :)
care to share the spec? so any future honda BOT can have some ideas where to begin with on their D16..
Bump: D16 homemade? :)
bought a turbo from saab 9000 i think... side mount intercooler.. bov etc.. then bring back install at home lo.. boosting about 0.3 bar on stock block... 450cc injector with safc..
:proud:
sounds good for street fun and gforce junkie
Bump: :proud:
not so fun now.. hahaha... the turbo oil seal is spoiled... blowing out white smoke now... hahaha
Bump: not so fun now.. hahaha... the turbo oil seal is spoiled... blowing out white smoke now... hahaha
Bump: maybe i settle this prob then i up my boost to 0.7 bar..
