I oso faced the same problem......... "krek.. krek.. kedeguk.. kedeguk". Just changed on last monday 1 pair of my upper arm and the cost is Rm300 inclusive labour charge. FYI, 1 pcs is RM130 only (genuine part made in Thailand) and for genuine made in japan the cost => rm 270/= for 1 pcs! I have no choice and need to change because already koyak!!!Originally posted by sleepy@Jan 11 2005, 15:22
then the upper arm pulak how much la?
haiya...
maybe we should consider toyota after this... muehehehhee :lol:Originally posted by sleepy@Jan 12 2005, 09:32
proton problem tingkap sangkut..
honda plak stupid suspension..
:ph34r:
Originally posted by kuNyit+Jan 11 2005, 23:38 -->
QUOTE (kuNyit @ Jan 11 2005, 23:38 ) --QuoteBegin-sleepy
@Jan 11 2005, 15:22
haiya...
I oso faced the same problem......... "krek.. krek.. kedeguk.. kedeguk". Just changed on last monday 1 pair of my upper arm and the cost is Rm300 inclusive labour charge. FYI, 1 pcs is RM130 only (genuine part made in Thailand) and for genuine made in japan the cost => rm 270/= for 1 pcs! I have no choice and need to change because already koyak!!! but till now, the sound still there!!!! :( dunno where coming from that sound!!! the absober damper already changes as well!! may be i oso need to check all front rubber bush as well [/b][/quote] i think if u r using sport spring especially progressive type one, the sound will be there. coz i'm using it now. not sure if this problem oso happen on stock spring... i oso feel so tired searching for so many noise coming from my EK... sighh.. :( |
wah lucky u using progressive spring but not noise..Originally posted by barracuda@Jan 12 2005, 11:34
hattech-v..
I'm using eibach prokit progressive spring match with koni on my EK plus Super Pro bushes..
no noise coming out front the suspension..lucky me
the sound very solid if langgar lubang during high speed..only thing so many rattling noise coming out from my dashboard..getting fed up with the dashboard
power steering oil ado ko idak? me experienced tis b4. check punye check kurang minyak lower than the lower level! after top up the steering ok edi.Originally posted by sleepy@Jan 12 2005, 11:59
hmm.. my rear no sound..
but my steering rase like damn ringan la..
duno y..
n if langga lubang i feel like theres sumtin loose..
ish..
fedup laa... :(![]()
yeah... my steering feel so ringan during high speed...Originally posted by barracuda@Jan 12 2005, 12:12
sleepy,
facing same problem 6 months ago...
streering ringan during high speed,
bila langgar lubang you even can feel the impact at your steering wheel..
check punye2 check my tie rod end bearing dah pecah..
get 2nd one and problem solve...
