*KRIOK* *KRIOK* sound when brake hard or when take corners
arturo
nooB
SateCelupLand
bros....i have this problem where my passenger side front suspension assembly makes this metal rubbing metal noise whenever i brake(which cause the nose to dip) or take corner to left (passenger nose rise) before this i only had this problem when heavy rain...but now even when dry oso got this sound...now its getting worse...can feel the judder thru the floor:banghead:. i sprayed wd40 on all the joints of the lower arm bar but still same problem...not sure if the bush already haus on the inside(looks ok to me) or other problem. anybody here knows whats wrong :confused::confused::confused: driving an EG8
It could be your inboard joints. spraying WD-40 wont help, you need CV joint grease, or a new inboard joint.
had a check.found the creaking coming from lower arm.looks like wishbone n connect from chasis 2 lower part of shocks.plan 2 go get it fixed 2moro.any idea wassit going 2 cost me?
U shud spent around rm300 - rm500 i think...
if more.. i dunno ar...
