To all sifus, gurus out der, I need ur advise n help
Last year, my brother has put in a GSR bolt on turbo in his 4G93 (SGTi) and had left the country after that. He passed on the car to me to use after that.
Anyway, this morning, as I was checking the oils and stuffs, I realized the gasket is leaking coz there were oil stains (quite badly) between the head and the block. So I started digging some information from ZTH forums about replacing to metal gaskets.
Actually I need your kind helps on several matters.
Firstly, my brother had already installed a metal gasket, but how come it is leaking. I presume he used a half cut / second hand one la. So after reading the forums here, I figured if I use a thicker metal gasket, it will have a lower compression. Where can I find metal gaskets, new or used ones, and how much will it cost?
Another questions is, the pistons currently used are GSR ones (or maybe GSR RS pistons), not sure which one but its definately a GSR. My bro had also installed a J5 Matspeed chip, remapped for GSR. So I was thinking, if I use a thicker metal gasket and get the J5 remapped again, can I boost the engine much higher? Currently boosting at 0.6 I think, don't have a boost meter so I don't really know. So can I increase the boost to maybe 1 bar since I am already using GSR pistons and J5? Or will there be any harm to the engine? Oh yeah also using GSR injectors and GSR ori BOV.
Also, do I need a feul regulator? And how much will it cost?
Anybody selling their metal gaskets here? Can you please quote me your price.
How much do you think installing a metal gasket going to cost me? Need funds :( as I am still a student le :unsure:
All your inputs are very much appreciated. Thanx in advance.
