hi, i want to know if there is any difference (when the car is stopped) by having the shifter into N and letting the clutch pedal go & having the shifter in say 1st gear and pressing the clutch.
Want to know when slowing down by both braking & shifting to lower gears, do heel toe method improve or worsen the braking distance, or does it have no effects other than making the transmission smoother?
its same as heel toe-ing right? but in this case, its for slowing down..
btw, since were on this topic, out of curiosity, when we do engine braking, will it consume fuel?
the rpm goes up to keep up with the actual car speed but will fuel go into the engine?
does it differ in carb n efi engines?
btw im just another noobie![]()
Another indicator that the oil needs to be changed is by looking at the color of the oil. Use the dipstick to find out both the level and...
