guan926 said:i want more bright & will apply amp soon.....
Then how about you??? Do you using EQ for your system???
jchin2 said:No EQ the sound not so nice 1..
jchin2 said:ok..when can audit ur sound? & share-share opinion.........
loon1031 said:I don't use any EQ for HU, flat respone for HU. No special EQ added.
Just use amp controll my ICE.
jchin2 said::Not_Impressed:
Earlier last 2-3yrs back b4 i play more detail into SQ i used to have the same thinking like u, no need EQ,HU all flat down and just use amp to control.....
But now i don't agree with u...If u put all flat down, player like Bremen & eclipse hv EQ build it and time alignment...If u put all flat down all this top HU are useless!!!
guan926 said:Preamp only for SPL ppl.....EQ is for SQ ppl....
Friends you know or not.....
Better go to learn from the SQ beginner.....
Or your can refer to http://www.autoworld.com.my for pras...
Also you go where listen SQ with EQ setting???
At Penang not much ppl know how to set EQ setting....I think the guy who tune EQ for you to listen is not an expert enough....
