the valve performance will be better.Originally posted by philipplim@Jan 31 2005, 14:10
just a important question to ask u all..
is there a difference between a twin cam 1.8 block and a sohc 1.8 block?
just wondering
cheers
phil
Originally posted by L2TurboFool+Jan 31 2005, 14:58 -->
QUOTE (L2TurboFool @ Jan 31 2005, 14:58 ) --QuoteBegin-philipplim
@Jan 31 2005, 14:10
just wondering
cheers
phil
the valve performance will be better. [/b][/quote] u r not reading the question correctly i presume.. from what i heard, there is no difference what so ever.. even refer to 4G9x manual also didnt see any difference.. but never realy check the real thing laa |
Thanks,i think i will go for half cut,coz i already ask my friend bout 3S-GTe half cut,celica,include MR2 gear box,about 2k ++.so,i think i will wait for the half cut,thanks a lot,by the way,wanna ask,wat mean by the Bar ... for turbo??sorry,noob hereOriginally posted by L2TurboFool@Jan 31 2005, 14:56
things you should haf for a turbo kit:
exhaust manifold
turbocharger
wastegate
downpipe
intercooler(depending on ur boost level)
piping
BOV
oil system
fuel system
ignition system
ignition and fuek control (engine management)
boost controller
things u need for a half cut:
cash
time
so..by that info you should see the obvious matter about bolting a turbo kit on.so much of money will be spent on ur engine and by this its going to reduce your engine's lifespan.
going for a halfcut would be so much better.
sorry..my bad.. ;)Originally posted by L9Turbo@Jan 31 2005, 15:25
U dunt need an external wastegate for a bolt-on setup.
Originally posted by tajulsans+Jan 31 2005, 15:28 -->
QUOTE (tajulsans @ Jan 31 2005, 15:28 ) Originally posted by L2TurboFool@Jan 31 2005, 14:58
@Jan 31 2005, 14:10
just wondering
cheers
phil
u r not reading the question correctly i presume.. from what i heard, there is no difference what so ever.. even refer to 4G9x manual also didnt see any difference.. but never realy check the real thing laa [/b][/quote] hhrmm...ne1 here done a convertion like that?care to xplain? |
better choice! ;)Originally posted by lorddie@Jan 31 2005, 20:47
check engine signal continues...
