I faced this problem a few months ago. Now solved already. I think mine was more severe, all 5 head cover nuts were covered in oil (my engine is a weak D16Y7 non-vtec ). The problem with most honda head cover is that the thread in the head itself is not through-hole type. Meaning that, if the seal under the nut is weak already, no matter how tight you torque the nut it will still be covered in oil. The solution: replace all the seal and put some new head cover gasket for good measure.
Maybe the thread loose already? If it is, go find workshop that has tap & die set, the thread can be re-threaded. You'll have to use slightly larger nut after that.
allooo sifu sifu aaa......how to make our car headlight flashing like F1 Safety Car...flashing left left..n..right right..nice woo...we can use it when emergency...like want to go to toilet hurry...
The 11th Auto Shanghai (Shanghai International Motor Show) was held at the
Shanghai New International Expo Centre in Pudong Shanghai, from the 22nd till
the 28th of April 2005...
