Over Boost - Motorsports
Beyond 20,000 RPM!
honestly, evo, never had problems with my evo engine, seriously hardcore and changing the spark plugs take 5 minutes by yourself, parts are everywhere
better spec c bro... or RAR...![]()
From the look of ur avatar mizunori, ur an evo fan, ur saying dat evo handles better than subey? Can test drive one haa? Is there a place i can test drive both od 'em?
sti n spec c = sepc c
spec c n s203 = s203
s203 n rar = rar
civic type r is win on chasis, not the engine.
how about my toyota levin stock with 6 speed manual?any vote?
type r is the best!pure power!no turbo.easy and not so expensive to maintain.not like subaru...expensive to maintain.K20A rules! :top:
civic with 4a-ge can laaa
---------- Post added at 10:52 PM ---------- 6 hour anti-bump limit - Previous post was at 10:42 PM ----------
for toyota 4a-ge 6speed 165ps on paper but when dyno it's only 145ps i vote the sound of 4age.....SOOOOooooo GARANGGGGggggg!!!!
TOYOTA BZ-R
Body type Coupe
Drive FF
Transmission 6 speed manual
Displacement, cc 1587
Engine model 4A-GE
Max.power (Net), kw(PS)/rpm 165 ps (121.36 kw) / 7800 rpm
Max.torque(Net), N*m(kg*m)/rpm 16.5 kg*m (161.81 N*m) / 5600 rpm
Power density 6.55
Engine type Water cooling serial 4 cylinder DOHC20 valve
Engine information
Fuel system EFI (electronic fuel injection)
Turbocharger No
Fuel type Unleaded premium gasoline
LEV system (Low emission vehicle) No
Compression ratio 11
Bore, mm 81
Stroke, mm 77
Final gear ratio
Fuel consumption at 10-15 modes, l/100km 7.9
---------- Post added at 11:09 PM ---------- 6 hour anti-bump limit - Previous post was at 10:52 PM ----------
EP3 TYPE R
Displacement, cc 1998
Engine model K20A
Max.power (Net), kw(PS)/rpm 215 ps (158.13 kw) / 8000 rpm
Max.torque(Net), N*m(kg*m)/rpm 20.6 kg*m (202.02 N*m) / 7000 rpm
Power density 5.53
Engine type Water cooling serial 4 cylinder DOHC16 valve
Engine information Chain drivehorizontal ranging i-VTEC
Fuel system Electrically controlled gasoline injection system (HONDA PGM-FI)
Turbocharger No
LEV system (Low emission vehicle) Yes
Compression ratio 11.5
Bore, mm 86
Stroke, mm 86
Final gear ratio
Fuel consumption at 10-15 modes, l/100km 8
INTEGRA TYPE R K20A
Engine model K20A
Max.power (Net), kw(PS)/rpm 220 ps (161.81 kw) / 8000 rpm
Max.torque(Net), N*m(kg*m)/rpm 21.0 kg*m (205.94 N*m) / 7000 rpm
Power density 5.36
Engine information Horizontal ranging chain drive
Turbocharger No
Bore, mm 86
Stroke, mm 86
Final gear ratio
ACCORD CL7 EURO R K20A
Engine model K20A
Power density 5.36
Turbocharger No
Bore, mm 86
Stroke, mm 86
Final gear ratio
p/s: I thought the signature boxer sound were non-existent in newer subarus....
heard it's about equal vs un-equal length exhaust manifold rite?gotta upgrade exhaust system for that sound :)
and i'm not rich and really can't afford...
