ECU Problem...Continue to read...
E-Tech
1,115
256
3,183
Johor
ONCONNET bro,
Checked your P08 chipped ecu just now and worked on it for 2.5 hours...
All 7 capacitors have been changed. The big cap C27 confirm leaked and caused problem to the surrounding area...
I also found the reason why the vtec no crossover and have repaired it.
All should be okay now. I just need to put into a car and test before returning it to your... Lucky you, it could be save...
Anyway I attached some pictures for you and as WARNING o other also.
Tq
E-Tech
1,115
256
3,183
Johor
Another ECU saved!
Onconnect...
Tested the ecu, ...
Result.... check light off after 3 seconds- normal
started da engine.... normal
idling steady....
drove it...vtec can on..
Will pack and return to you asap. Tq:adore:
AD_EG
6,328
231
Ipoh
congrats bro.. :congrats:
will update you once my mech has confirmed what he wants to do with my old ecu....
AD_EG
6,328
231
Ipoh
eh bro...my mech said he can repair him self leh....so he keeping the ecu...sorry ah bro...
pencalat
805
19
JB
item received yesterday.... tengkiu e-tech
pencalat
805
19
JB
Bro
received... Ok, that is courier company responsibility.
Tested?...this is my responsibility!
How? Can start? Vtec can open?:biggrin:
not yet tested coz my fren got course this saturday and sunday...
maybe this monday he will tell n report to me....
E-Tech
1,115
256
3,183
Johor
Donate ur spoilted ecu and save another
Honda from extinct. U can reversed couirer
charge to me...
Help out ur hondarian...tq
awannz80
33
hi bro n sifu vtec, i've checked my ecu its P08 n its seemed ok, i wanna change the capacitor as advised, the problem is, the ecu is somehow very tight and canot be unplugged, pls advise, sori for the stupid question but its do happen
AD_EG
6,328
231
Ipoh
confirm can unplug bro...just need to hold the clip down...there is a lever at the middle of the ECU socket...you need to hold/push the lever down and pull out at the same time.....with some force..
E-Tech
1,115
256
3,183
Johor
Bro
tight means virgin.
Grip wires with one hand, press da clip wit tumb and
shake it out...
Or press clip wit one hand and da other hand wit screw drive
in the slot and push it out. The left hand continue to pull..
Ok?:biggrin:
awannz80
33
tq bro, will try it again this weekend:shot:
hi all car expert!!
just wanna ask, is it up boost our car equal o up our car's power?
can any1 explain it more detail?
if really do so can up power,then why people still need others mod?
if gsr up boost to 1.0 then roughly how many HP will i get?
is this oso help to increase the top speed?
will this affect our engine?will overload our engine?
really appreciate of your ans..thanks very much!!!!
