add 1 more 2 channel amp
hmm..spykey..may i ask u bout the dun share the grounding part? means both amp punya grounding..kenot share same place?
yes bro..both amp dont share the grounding point.
layman term can share la but if u serious in SQL,better separated it and grounded it as close as possible to the respective amp
ic..wut is the effect if ground together? as my one is both connect to one grounding point..the shop actually splice the 4ga cable and connect both together...
diff ppl diff theories la, some will use ground as close to amp as possible, separate points, some will have single point for all amps, some will even pull all back to battery, all sorts of ways lah. as long as u dont face any ground related noise then it is ok, if u are, then try the other methods, mine is still separate points, close to amp...
ic..mine is to one point..but no aeroplane sound..so i think wil jst keep it the way it is..
Write your reply...
