i drive from setapak to Port Dickson n from port dickson back to setapak.....rm35 petrol....ok or not?
According to Clarkson, when you're coasting like that in neutral, the engine still has to use a little bit of fuel to keep the engine running. But if you leave it in gear and coast (without applying the throttle), the modern engine uses no fuel at all.suprafire said:4) I am drivin manual so when i am on a straight road or going downhill i let the car run on free gear... means the car is rolling on it's own momentum and the RPM meter shows idling rpm...
yolk said:65km/h ... my GAWD !!!!! die of boredom !!! hahahahah
not a good practise from safety point of view.suprafire said:4) I am drivin manual so when i am on a straight road or going downhill i let the car run on free gear... means the car is rolling on it's own momentum and the RPM meter shows idling rpm...
. I love how the car looks, it can look pretty menacing with the right bodaykit. thanks silverfish.
cheers
