Turbo Charge 850cc DVVT-VIVA engine
jegvd
hi sifus,
i plan to turbo charge my viva 850cc engine. This project just considered as soft turbo application and not for hard turbo application. So, i plan to maintain the internals. This setup just to overcome to low end power/ pick up power which is current issue in the engine. So, kindly advice the items and mondification needed.This using 2nd items such as turbine, intercooler, injectors and etc.Boosting max 0.6 bar with safc/e-manage.
hi jinkl,
thx for ur advice.Can u list the items from me which i totaly need to turbo charge the car?
go for L2/L5 or avy l250 stuff as per jinkl sez... aside from parts that you've already mentioned, you can add metal head gasket and twin layer alloy radiator combo!
dun forget to change ur exhaust to at least 1.6' if you planning to change to std daihatsu turbo... preferably 2'... since money is not an option, why not custom ur downpipe as well...
and get urself a good tuner for all the mods...
maybe other sifus can help.... i'm only stating back what some of my frens do to their 850cc/1000cc engines....
maybe you can refer here... http://www.geocities.com/flamefox850/index.htm
although he's more of power-chasing-kinda-guy, but at least you can get some pointers on his methods...
good luck... :driver:
p/s: dun forget to upgrade ur brake system as well....
where to get the metal gasket for viva 850cc engine?
That one I don't know... but should be avaliable since I've seen lotsa 850cc ED block (ED-10 or ED-DE) turbo monster around...
and since your Viva still uses ED block (code name ED-VE rite? look into the svc manual), i'm sure it's bolt on ok....
You can ask around some shop that do bolt-on turbo such as RSImpressive, D'Pro, Ejam motorsport etc... always read about them in the car mags somewhere... :hmmmm:
mind asking where ur loc?
ok.thx
loc at old klang road.......
Good luck wif your conversion.... if possible can update here wif dyno eh? :adore:
FYI, found websites that might interest u
http://www.d-pro.com.my/contact.html
http://www.rsimpressive.com/contactus.htm
p/s: Ejam motorsport doesn't have a website but i heard that they are based in klang
any other advices to be shared......from other sifus
hi sifus,
hi jegvd... seems that u want extra power eh? ahahaha.. so good then..
if i were u .. then this is what i might use for this mods :
1. td04-09 turbine twin blade from pajero diesel or maybe L2/L5 turbo for fast response!
2. intercooler + stainless piping
3. banana, to replace stock exhaust extractor
4. safc for pocket saving ... coz after all we only need to find fuel setting... ignition tak payah pun takpe for this soft turbo...
5. fuel regulator
6. metal gasket... can use kelisa/kenari metal gasket ... *eh, btw this viva how many piston ahh?? 3 ke??
7. injector.. i think stock injectors can support 0.6bar *with help from fuel reg and safc.. or for safety purpose maybe can use 240cc injector from perdana or vr4 n/a ..
8. maybe a bigger fuel pump might help *rb20, gsr etc etc
for me, in every mods, fuel delivery system is the most important ... so i hope this might helps..
hehehehe.. cost maybe around RM 2K ++ .. and dont forget to wide band your ride!
p/s: heard that viva pistons already coat with ceramic coating.... *dunno whether true or not... but a lot of people say that.... >:)
hi sifus,
bro.
looking at the pic of yur current wira, i wonder whether you still need advice arr :biggrin:
