..wow!!!now sc going to turbo!!!! hmmmmm...sounds good!!!!
time for another
..wow!!!
share la your plan..and specs too..
not yet ler.... still has the feeling for SC ler..nexst step maybe..SC14..before going for turbo ler..
ekekekek..
bro, masuk turbo terus la. no need to pening
conversion to SC14 is abit headache la. Anyway, my next project will be;
- changing to 20v BT 5 speed gearbox
- Lighten the flywheel and using exedy clutch
- installing bosch or walbro external fuel pump
- tuning with wideband sensor
die... vtec... die.... hahahaha
i'm quite pening....:hmmmm2:
i will buy my friend's AE101 supercharger in the next few days,
but now, the alternator problem...
he said I.C(if i'm not mistaken) was burn,swap with Camry and other Toyota car but unresolved.
need help from sifu(s), was it valid to use other 4AGE alternator?
if not, where can i get the 4AGZE alternator?
Im not supporting Honda or Vtech as im toyotarians too but dont you feel there is something wrong while you using supercharge vs vtech which is NA, those vtech can argue even if you won the match since you are charger not NA, you are not in the same class with NA,try to think logically bro, if those vtech CHANGE TO CHARGER then only you can claim your rights...dont make a fool out of yourself with your last statement
(dont take it to heart,its just a friend reminding one another..cheers)
Miriguy.....u wan the inlet manifold structure.....tomolo i go and measure the size than i tell u wat measurement is that inlet manifold.......
if u wan to use the td04 to boost 1.5 bar .......i don think the the turbo will last long.....my friend's mivec turbo he using td04 his max boost is about 1.1 bar only and a vios turbo using td04 also 1 bar only.....if u wan get higher boost go for bigger turbo....
bro, how much to make the throttle body?
shamburke bro....
i'm at USJ subang jaya...
n the current owner oso said, need to replace the left problematic driveshaft...
m@antis, we got the same problem here....
what if the alternator being re-con to a person below:
http://www.zerotohundred.com/newforums/engine-and-performance/148626-starters-and-alternators-specialist.html
thanks a lot shamburke bro....
what is a a good brand pulley belt? My belt always slip when i reach 7500rpm. this caused my boost to drop. any recommendation on good beltings?
