4agze + E-manage Ultimate
uniquetrueno
San Antonio, TX
Hello guys,
I am located in Texas, San Antonio. I am driving an AE86 with JDM AE92 DLI 4agze. The only mod the engine has is the 180mm crank pulley. I am going to install a E-manage Ultimate sometime in the August.
However, I could not find help in USA at all. I had no luck contacting Greddy USA. Can any of you please help me with the wiring?
On the Greddy installation manual, it has the ECU diagram for AW11 4agze. These are the wires from the Greddy manual.
#E Sensor Ground
t No. # ignition signal
E Ground
#1 No. 1 Injector signal
#2 No. 2 Injector signal
G Cam Angle Sensor
Ne Crank Angle Sensor
I RPM signal
W Water temp signal
Th Throttle Signal
SPD Vehicle speed signal
A Intake temp signal
Ar Airflow/Map sensor
Kn No. # knock signal
+B Power
I tried to find those wires base on AE92 4agze wiring diagram. I could find most of the wires except for the MAP sensor signal ?!!
Also, what kind of fuel injection does AE92 4agze has? is it individual or group injection?
How do I hook up the ignition harness? Do I follow the "4 cylinder group ignition" or "distributor type ignition"? I am guessing its the "distributor type" because we only have 1 ignition signal to the ECU, is that right?
My last question is the harness for knock, water and vacuum temperature. Do I pick just 1? Or I need all 3? Because "knock 1 is sharing a wire with water temp" and I dont see a "knock 2/vacuum temp" on my Emanage harness.
Thats all the questions I have so far. Please help me out guys...
Thank you very much
