muahahaha!!!!!
Hmm... I'm surprised, you do understand. :hmmmm: Then why are you still asking for something so difficult to achieve ? It's worse now, you want increase in BOTH torque & Hp ! :hmmmm2:
It's easy to increase 30 Hp on a forced induction engine but on a natural aspirated, it's quite difficult especially when the BT is considered to have achieved the benchmark of 100 Bhp/litre mark.
So far I can only think of a bolt on is NOScoz it's not feasible to force induce the BT as it'll cost quite a bit to do that. So my suggestion'd be a metal gasket, a piggy back & a pair of higher cams. That'd probably get you near to the 30 Hp on crank you want, bro.
If someone here has a more practical idea, I'd also like to hear him out coz I also have a BT auto but I'm not complaining coz I'm no expert in driving fast in an auto trans car. I fell really scared in having to rely so much on the brakes alone.:afraid:
to be easy..i wud like 2 prefer on torque ..
Easiest and cheapest way is to turbo your BT. Can easily hit 200bhp without breaking your bank account. Its cheaper than NA modding. However, need to change to low comp piston, thicker head gasket and custom header. Also need e-manage for tuning.
Last time, I seen one 4A-GE 20V BT + big Axx Turbo with 25+ psi boost powered with 4A-GZE piston (Black head), king bearing, thicker head gasket, external wastegate, BOV, intercooler, oil cooler, custom turbo header, adjustable cam pulley, high cam??, Bosch ignition coil, cooler spark plug, bigger injector and halftech management system. Almost forgot, It is a single throttle setup and with VVT disable. The AE86 is belong to one ext 4AG tuner in KK. vh-101, you can call Ah Lun from Bengkel Kolopis on turbocharge 4AG stuffs.
