ZTH Miri Members
anyone know where to do alignment and chamber cheap in miri here??
pricing roughly the same everywhere. alignment is usually no prob but camber depends whether u have a adjustable upper arm or not. usually stock suspension dun have it you have to buy aftermarket ones and its costs for cheaps or a few hundred depending what type/brand u want.
other than that there is the old washer insert trick. cheap and does the job.
your pick
its camber-lah not chamber
depend what car u driving. camber kits (if available for ur car) is not cheap too. the rm60 bucks i think it is labour charge only. alignment only around 30-ish and no aftermarket parts required.
even a simple adjustable upper arm for the rear brakes for EK costs a few hundred.
if u wan to avoid adjusting camber next time select the rim similar to stock offset. but if u go lower springs, u definitely need the adjustables. washer inserts can only do so little.
yup, normally they just replace the camber bolts and nuts, unless u wanna add the camber plate for extreme negative (or positive, if u want..)
i tot it's just changing the skru only?? which cost rm60...
change screw and cost 60 bucks? good money. Stock cars come with some degree of camber on the back wheels. with stock offset there wouldn't be alot of uneven wear problems so it does seem abit awkward but its fine.
unless u changed your wheel and noticed uneven wear then very likely chose the rim with wrong offset. u might be able to remedy this with spacers and such, but u might end up with clearance issues of the tyre to the fender etc.
check around with bigwheel whether rm60 includes labour plus parts for camber adjust. I think many of us would be keen to know too.
btw its not a screw but a bolt.
wooohooo~ raining non stop lately, be sure to get ready raining slick tomorrow!!!
yup it is including the labour cost... drag still going on ah tomorrow? i mean later in the morning?
helloo guys, anybody..can share the drag photo? dammit, i have class this two days cannot go watch the drag.huhuhuh
http://chinese.cari.com.my/myforum/viewthread.php?tid=959787&extra=page%3D1
tis website got !!!:burnout:
quite disappointed. Rain causes the drag to stop.
Evo from sabah caught fire and GHK is not performing well.. hehe..
