semi slick or normal tyres
Din know it will be less comfortable.. then i think i will stick back to original size.. thanks bro!!
my car original tyre size 225/45-17 on 7.5jj wheel...
now i'm using 235/45-17 spot on....
u should have no trouble using 235/45-17 tyre.... atr sport 2 tyre fits your budget and pretty decent compared to much expensive tyre
You car power mah! can use 235.....:driver:
---------- Post added at 08:15 PM ---------- 6 hour anti-bump limit - Previous post was at 08:15 PM ----------
Can but the tire sidewall will be thinner by about 0.5cm and the ride will be harsher/less comfortable. I suggest you stick with 225/45, it's still common size and should have plenty of choices what.
215/45 more common and more choices and best of all very much cheaper....lol:rofl:
KeeSeong
78
508
haha..as mentioned by VR2turbo, ur car power ma.. later i put 235 car slow like turtle.. hahaha
hmm.. 215 or 225 or 235... alamak.. confuse..:banghead:
Haha can't be consider as a race car lah.. crz with bot only...
Hmm if CRZ then 225/45/17 is max size already and 235/45/17 will be too big coz std size was 195/55/16. Actually 215/45/17 is the closest match in diameter but yeah a bit harsher ride. Maybe you should try someone else car which has 215/45/17 to know how it feels. If still ok for you then you can downsize.
ken yeang
6,617
1,327
bot already can smoke many cars on the road. With semi slick.......more terror...
Similar threads   Forum
Wheel And Tyre
Wheel And Tyre
  Similar Threads
Wheel And Tyre
Wheel And Tyre
Hi all,
Anyone knows how to D.I.Y install a 6.5 inch speaker into the front iswara door? This is the special edition iswara (the silver coloured). Go to one shop, say hard to install. One more say cannot. So... what to do? D.I.Y la I guess.....
If you guys think this is not possible, can you please help to advise other locations? Thanks.
