Emanage - stock evo 7
satria81
PETALING JAYA
Hi all,
My car is at 100% stock condition but I recently noticed that an EMANAGE was installed by previous owner.
What difference would it make if I were to remove the EMANAGE. Would it reduce the performance or. . ?
Kindly share your thoughts.
Note: I have no plan to mod my car, I bought it simply because it was at stock condition or just the way I like it to be
thanks all !
Regards,
Satria81
Depends, did they increase boost or not..If they increase boost, then yes it will reduce performance, and the boost without fueling may kaboom your engine.
hi ixeo,
thanks for the reply.
I do not know if the boost pressure has been increased . how do I check..
would it be better to run the car stock without the emanage, please advise
hi ixeo,
What is your current max boost readings? Did you have any boost gauge installed?
better dont remove it as even stock also it made different...
so good, buy car free e manage...
yeap
but the emanage device looks old and faded :) I am not really liking it but if it makes a positive difference I shall remain with it
look for a tuner..have the e-manage check..got tweak or not..
or maybe the tuner can fine tune it a bit more..:biggrin:
I am wondering if the emanage is the culprit as I am only getting 270kms +/- for a tank of fuel presently, given a choice, I would go for stock set-up
with an emanage u may get better fuel economy depending on tune. stock ecu runs the car with very safe parameters.Normally on a stock engine u cnt do much with an emanage but trim down these parameters. you might wanna invest in monitoring systems for your car. if ur running boost its always best to get good quality gauges to monitor. or else you wont knw ur oil temps, u wont realise overboost and etc..
Evo 7.. ECU can be flashed right? Why want to install E-Manage, really tak faham.
If there's no boost controller in your car, and the stock boost solenoid is controlled by the stock ECU, you can safely remove the e-manage.
try to re-tune your e-manage. you'll get much better fuel consumption with a good tuning. Possibly the previous owner mod this car before and change back to stock before selling the car, but he didn't send it for re-tune. :listen:
I would agree that the previous owner would have modded cos why would someone run the car with an emanage without race cams/ pulleys etc
my fuel consumption is high. from full tank of petrol up to empty, I wud hardly get 270kms.
Ouchhh, that's hurt. Such a fuel guzzler. It might be right, but some of Airtrek's owner install e-manage to get better consumption and run safely on ron 95.
evo7 run emanage? cheap fast way for mods...but the tuning is rough... ecu can be flashed but use piggyback for what....
i suspect prrvious owner either too much money or scanmed by certain ppl/shop....
and my suggestion...go for a dynotune to check the engine tuning first.......after get the baseline then remove the emanage...sell it and send your car for ecu flashing and tune to suits your car "proper" needs....
and please get essential meter for easier engine monitoring...most: boost+water temp+oil temp gauge...
New Posts
