Knocking/Pinging - Really bad or harmless?
Jose
243
36
Subang Jaya
sometimes even on ron97 also i experience some slight knock on my car. bad fuel ?
Actually it depends. I have tested a few different brands of 97 including Vpower Racing. The worst of the lot seems to be Shell. This applies even in Singapore when I used their RON98. I would get knocking at the higher rev ranges no matter what. Don't know what's the main difference between the brands but the best seemed to be BHP for me, followed by PETRONAS and then Esso/Mobil.
boyzone
2,669
5,148
Malaysia fuel not clean!
is very subjective as difference engine matched with difference petrol additive formula.
For me, Proton, Produa & Mitsubishi engines are well suit with Petronas.
Could be or your engine highly mod?:biggrin:
---------- Post added at 09:24 AM ---------- 6 hour anti-bump limit - Previous post was at 09:23 AM ----------
Nowadays hear less of these cases. Those days plenty, mixing kerosene and all that....
---------- Post added at 09:27 AM ---------- 6 hour anti-bump limit - Previous post was at 09:24 AM ----------
You also? I tried Shell Ron97 FS formula before their V Power. It was so bad that I had to siphon the fuel out. After that no more Shell for me even though they change to V power formula.
BHP good, means their 800ppm is good?:biggrin:
Still stick to Esso/Mobil which is Petron now. Running okay and got smiles points.....hahhahahaha:biggrin:
Jose
243
36
Subang Jaya
Yes, mostly experience it when fuel up with shell 97. but i do experience it on mobil 1 fuel as well. it's on low rev when i wot there's slight knock on 3k rpm then the sudden surge at 4k rpm. and this usually happen on a hot sunny day. on a cool day eg 24-26'c car is smooth as silk. Suzuki Swift Sport with just some minor mods such as intake and exhaust with emu.
Sayko
Jul 24, 2014
Turkiye
i have knocking too, but when i drive with lpg, i have no any knocking with petrol... i doupt about distributor, i just bought ignition plugs and plug cables.
boyzone
2,669
5,148
Just pumped Caltex RON95 ...so far no knocking even though run with duratec 272 cam :proud:
TheDuckster
122
14
forum.lowyat.net
Sometimes it takes up to three tanks full for the engine to adjust....
so the consensus is fuel from which company experiences the least knocking? :biggrin:
Cannot say as different people have different results even with the same make of vehicle. Best is to test them yourself and see which fuel suits your car.
I tried Shell old FS formula Ron97 and it did not suit my VR so I went back to my Esso/Mobil which is now Petron. Since running fine on this I rather not test with other fuel, but another main reason also I have two Petron stations near my home....:biggrin:
muzhaffar
251
41
Dont expect to demolish knocking from ur blacktop. It requires ron100 as a standard
Kopi
875
15
3,018
Cheras
how do you even define 'knocking'?
sounds from the cylinder head? ignition misfiring as pre-detonation?
数学代写系还将开设许多“应用数学”课程。许多人可能想知道这些是否与他们未来的工作直接相关。事实上,所谓的“应用数学”有着非常广泛的含义。我理解应用数学是将math的思想、知识和方法应用到物理、化学、生物、金融、工程等学科和行业中,帮助解决学科和行业的核心问题,促进科学和行业的进步。mathematics系课程中真正与实际工作相关的applied mathematics知识和方法(如工程、金融等相关知识和方法)所占比例很低,可能仅是金融数学和计算数学课程的一部分;数学专业学生接触最多的应用数学,主要是对其他学科理论问题的分析和解决。因此,我们可以普遍理解,数学系学习的应用数学与我们生活中的“应用”有很大不同。
