if the bottle have gas inside means its your compressor at fault, if no gas could be punctured cooling coil or condenser.
Means you air con running but no cold? Need more accurate feedback.
Main thing is the compressor, is it running? Magnetic clutch activated to run the gas.
Enough gas or not, see receiver drier whether gas bubbling or near liquid form
If not enough gas then got leak some where
If enough gas, see fan speed fast enough or not
Other then that will be the expansion valve at the cooling coil
Does the receiver drier ice up?
What if the air cond compressor kick in and off, in and off? Compressor faulty?
Mine say my car is on stationary. On gear D, when I turn on the air cond, legs on brakes. The car will jerk in front.
Then the sound of switch on and off sound from the air cond.
Wiring or Magnetic clutch problem...
Last Saturday still not done?
He couldnt check whether the car is jerking. So after done all, when I about to leave it starts again when I switched on the air cond. So I showed him.
Then will do at next service since was late adi.
.....hahahaha
Car always act perfectly when at the mechanic.....hahahaha
Like bringing own son or daughter to clinic. Reach clinic when doctor say need injection, suddenly no sick already![]()
Ts when are u going to give us an update on ur car? :D
Newbie
| hi i wanna sell my evo 9 manufacture year 2005 register year 2006 import baru ap baru stock standard accident free aluminum roof mivec turbo 6 speed regular service recaro leather seats cd... |
