I remember bro. TR call it a driver....
I don't think LEDs restrict the flow of electrons. They just emit light as a side effect. I don't know what you call the black diode, the line around the top indicates the direction of the electron flow. That's about all I know. :ahhhhh:
IT JUST HIT ME! I REALIZED WHAT I DID WRONG!
I connect pos to pos and neg to neg.
While the diagram shows pos to neg. Alamak. So thats series circuit!
:stupid:![]()
Redo your project......![]()
De-solder or order new LEDs?
I still have 150 more.![]()
And also desoldering it and take those that still can be used.
Yes it does. It's just that it emits light when current flows through. Diodes are useful in by-pass, voltage regulating, and amplifying. It is used to guide current to capacitor and not flowing back to complete a circuit therefore it charges the cap. Very interesting. Regret that I dint learn well during school days lol
HAHAAHAHAH! School's Kemahiran Hidup basically useless.
What diode is it la. I still don't get it.
A diode is a device that allow the flow of current to be in 1 direction only. Similar to a 1 way valve. You can find them used in solar panels where the heat is converted into energy and stored into batteries. Then a diode is placed on the input path of the battery so that the charges that flows into the batteries does not flow back into the panels as it will be a waste of energy and your battery won't be full. Our handphone batteries also have diodes inside.
Also don't get confused with diodes from Zener diodes. Normal diodes can't regulate voltage.
http://amrita.vlab.co.in/?sub=1&brch=282&sim=1207&cnt=1
VR2, driver is different. driver looks more like an IC chip.
Yes that black components is DIODE. You can use IN4001, IN4002, IN4003 ~ IN4007.
But if you want to use the brake function, it is recommend to reduce the no. of LED in series from 4pcs to 3pcs.
Then you may use 180ohm 1/4W for R1, 100ohm 1/4W for R2.
Tail light current = 20mA
Brake light current = 30mA
(V BATT = 13.2V, V LED = 3V, V DIODE = 0.6V)
Revised diagram as follow:
Yes for intermittent usage, you can go slightly higher than recommended current. I set mine at 20mA/35mA and it last me for more than 5 years without showing any difference in brightness.
---------- Post added at 11:13 AM ---------- 6 hour anti-bump limit - Previous post was at 11:08 AM ----------
Most old age proton car force their LED brake light's current to as high as 55mA, that is way above the spec. Thats the reason why those car's brake light fail in within 2 years. I think they intentionally did it in order to cut down their material cost (by using standard brightness LED instead of High Brightness LED) or to increase their spare parts (3rd brake light) sales!
No time for DIYs! The diagram u did yourself, Levin?Hey guys, just realized that when brake light is ON, tail light will remain ON too.
In that case, we should increase R2 from 100ohm to 300ohm.
R1 = 180ohm 1/4W
R2 = 300ohm 1/4W
Current flow through R1 (Tail light ON) = 20mA
Current flow through R2 (Brake ON) = 10mA
Total current flow through LEDs when Brake ON = 20mA+10mA = 30mA
(Conditions: V BATT = 13.2V, V LED = 3V, V DIODE = 0.6V)
Happy DIY!
, i'm looking for the good condition original 350Z exhaust. If you want to let go your exhaust please let me know ya..
