u go as far as u can,dependant on d firstly ron and den ur system's limit
Octane number only determines the ignition temperature. Low octane fuel ignites at lower temperature / pressure inside the combustion chamber and high octane fuel burns at higher temperature / pressure. If talk about pure fuel without any additives, they are pretty much the same except for the sentence i mentioned above.
The 'power' from RON97 over RON95 is actually provided by the additives (from an engine which is compatible with RON95 or even lower).
I would say that RON97 fuel from Brand A isnt necessarily better than RON95 from Brand B. It all depends on the additives and the so called great formula.
Err..sure dowana open another thread for this ar?
Well I can see where your question is going - additives providing more power than the fuel itself. Fuel is the energy source when it burns. We are not pumping additives and add fuel into the additives, are we? And frankly speaking I'm not a petrochemical engineer or I work in fuel processing R&D department. So I don't know what additives they put in. If I do I might be rich lol...
So when fuel comparing to each other, RON95 or RON97, without any additives, the only comparison we can do is the octane number. And octane number doesn't equal to power.
Btw does B16 has knock sensor? If yes then it might be able to adapt until certain RON number...
yup..got it there...
fuel that provides energy...the power source..
additives use to increase octane rating..lubricant...bla-bla...
List of gasoline additives - Wikipedia, the free encyclopedia
Higher RON can produce more power only if the engine advance the ignition timing (or manually)..
If not...hope you get the point..
i might open new thread later today for this..![]()
Yup, Basically if your car originally is tuned to Ron95, with Ron97 it does not make any difference.
I tested my Old Hyundai that requires Ron91 only and no difference....:rolleyes:
But if your car is originally tuned to RON97 then using Ron95 will have loss of power. Bringing down the ignition advance is actually bringing down it's power too.
This one I tested my VR and it cannot go pass 4.5k RPM and knocking starts...![]()
Yeap that is it. The octane number doesn't mean the power one can churn from the fuel. It is the engine tuning itself that utilizes the octane number. It is sometimes tired and sad to hear many people including some of my friends and families believe that RON97 is more powerful than RON95 because it is more expensive, premium, high number (97 than 95, but most don't even know what the number means and what it does), etc.
And it is even more saddening when I tried to explain to them the theory behind but the acted in a way that I'm a fool and baseless, and that the rumors by others of their kind are reliable. Talking bout pride...
I wonder where is the TS btw...to the TS, does your engine knocks running on RON95, at both high or low rev? If yes, then either tune your engine or use RON97 or add octane booster. If not, just keep it that way and your engine will be fine.
Actually one can just look at the US who only has max RON95 available anywhere, but yet they also have most cars in the world sold there, be it slow econo cars to hyper cars with scary power levels, and all those still can run perfectly ok with the available RON95, don't they? :) So that should answer any doubt if RON95 will damage your engines or not.
Few days ago I also saw an episode of 5th gear whereby they tested several fuels of RON 95, 97, & 98 on a Golf GTI. The result was some of the higher RON do produce a bit more max power (some up to 3-4HP) but other also only produce quote]
The GTi is high performance, therefore Ron98 will definitely gives more power than Ron95
You know - I hate to personally admit this cuz I've also used the "The USA are using RON95 as premium petrol" but there's actually a flaw to this statement. The Americans don't use the same gauge as us when it comes to measuring the octane levels of petrol. They are actually much more conservative and have other things taken into consideration. I can't remember the exact explanation but RON95 to them (ie - premium gas) is almost the equivalent to our RON98 or 99.
if ur engine comes with an ecu and it has a good knock detection system,then there must be a different when using different ron values. my rides give different pulls when changing between the two ron values,so they are quite correct when saying one is better den the other
Well actually the US octane rating is based on AKI (Anti-Knock Index) which is avg. value between RON & MON (Motor Octane Number). They have only up to 91 AKI rated fuels which is widely available in the US. Converted to RON, it should be about equivalent to our RON95 maybe max RON96 at best, but not yet reaching RON97-98.[
Correcto up to the point.... Their premium unleaded gasoline rated RON95 should be @ RON97 at the lowest since the difference between AKI and RON is that AKI rating is between 4 - 5 lowere than what the RON stated
One interesting fact though, most of the JDM tuners in USA resides on the west coast, and in particularly in the California where most of the time the RON max out at 91 (RON95 - RON96 for us)
so if they can say they can run 300whp B series running on regular gas, we should be paying attention to them![]()
[/B][/COLOR]
As i said, when im running on my B16A with RON95, i found no problem at all. Happily rev until 8500rpm, no knocking detected. Its just when i cruise along, den i rtelease my throttle pedal, ders a explosion sound occur from my exhaust. "Bup bup bup bup". I wonder what sound is dat. Only happen during decceleration, not acceleration.
---------- Post added at 03:23 PM ---------- 6 hour anti-bump limit - Previous post was at 03:21 PM ----------
Sorry bro.. Baru balik from LD. Doing weaponry assesment over there. Huhu.. Just coming back last Sunday. Happy to see my family and My car safely. hehehe.
As per topic,does anyone know wherether S13,S14,180sx starter suitable for S15? And anyone know what is the part number for S15 starter? |
