but make sure u buy 1 unit only... more than that i think is taxable..
Then again.. If hondata is right, then at peak, I'm running 100% duty cycle off the injectors, and I should get that number at flywheel, which I do, if that dastek dyno numbers means anything.. hahaha.
Hehehe.. interesting how the injector sizes and duty cycle corresponds to flywheel horsepower output.
Anyone care to test out this theory of mine on their ride? It's going to be an experience, I bet.. either my theory is gonna sink or swim depends on it as well.. :P
Chris, since you have logs of all your car tuning stuff.. mind pmming some? Let me pore over the data and see what's what..
Like your 205hp setup for example.. probably making something like 230-240 at the wheel, could be lower since your friction loss is probably lower due to the lightened cranks, no a/c and stuff.
so I need stuff like
a) injector size, which is probably 310cc (your RC eng injectors?)
b) fuel pressure, which is probably 3.5 bar at WOT, like mine.
c) max duty cycle, which is also likely 100%?
I'm hoping to come close to at least guessing engine hp number (with an error margin of 10hp or less) by looking at injector size, duty cycle, and fuel pressure.
Amazing how my curiosity of why americans plonk in big cc injectors in an NA setup takes me.. :P
- im not sure if hondata s300 has the setup for injector lagtime, with this you can alter the volts for your aftermarket injectors appropriately so it doesnt show 100%all the time.
- yes indeed they said 100% duty cycle for 240cc, but that is for the b16a and b18c basemaps. stock basemaps and not rojaks with 2L blocks and other aftermarket combination. they assume you can pull new settings from the basemaps.
- if you have notice emanage has a percentage difference(compensation) if you put a bigger size injectors.
the americans has been using hondata and power-fc on their hondas. its not taboo for them to use 440cc on a b16a since they can control the injectors and its a 1 time purchase. then again, more fuel is always better than less fuel, if you can control it.
commonly the 240cc also can be use on a mildy(basic) 2L setup and commonly phrase "sureeeeeeee cannnnnnnn oneeeeeeee"...yeah if the a/f ratio is nice on the dyno.
the bang for the buck malaysia-boleh will always be pushing the FPR(4-5 bar), running on some supra/rx7 fuel pump and maxing the stock injectors. its all matter of time when the injector starts to jam and mrs detonation is knocking on your door...ha ha ha
S300 can set for injector size. You will have to key in 240cc for stock injectors and current injectors if stock then type 240cc if 440cc then key 440cc.
From here Hondata will take over and allow your car idle almost like stock 240cc. :shades_smile:
My 205whp B18C setup on fuelling:-
Stock ITR Fuel regulator
Sard 280L Fuel Pump
RC 270cc injectors
all run on a very rich endurance tuned J's Racing N1 ECU
True, but one thing I noticed is that the injectors start to sputter if it's pushed beyond it's limit.. during a tune, observed that with too long an injector duration, the a/f ratio bounces all over the place.. it drop to lean at around 15-16+, then suddenly very rich at 10+ AFR.
During this time, the car jerks like mad.
Yeah.. actually can they compensate the injector duration when you enter the values.. played with the app for a while already. It's a no brainer to plug in the bigger injectors (with the resistor box if required) and then change the injector size, and you notice the fuel map is adjusted accordingly.. neat stuff.. :P
but Chris, your BFSC is sure very low if you can hit 200+ whp (220-230 on engine?) with 310 injectors at only 7x+% duty cycle.
Curiously enough this happens only during the vtec point.. I think it's something to do with the pre-vtec fuel enrichment on the ECU just before the vtec engages, which is just enough to send the injectors to the edge.
Hopefully with an injector change and a retune, can get that elusive 200whp at 8K on a 1.8+L engine, and 215whp.. (hopefully). It should be soon, although the date is still tentative.
Cross fingers and hope for the best.. :P
From my experience, the A/F jumps around because the car is jerking and not because a/f is jumping causing car to jerk.
And this jerk if it happens will always happen only in vtec transition point or part throttle in higher rev like 7k, 8k rpm etc.
I don't exactly know why it happens but i know for sure if cam gear settings are not optimal setting for your specific engine build, compression etc, this will always happen and also if the vtec point and iginition + fuel map is not ideal it will happen.
My 1st cam i used was Jun2 and Jun3. Both this cam had crazy mis-fire or jerk during vtec transition and part throttle. No matter how we set the cam gear, it could not be eliminated with retaining good power. all this was done in old skool style with a re-chip ecu.
The EK i know for sure, after install S300 and did a good tune and setting vtec point high the vtec transition was smooth and alot less jerk at part throttle.
My recent cam installation on the Buddy clubs, when the camgear setting not ideal, it was jerking like help in vtec transition. Now solved with only camgear setting.
why today c2 is good?
chris,
u actually said the solution, prolly u didnt realise this chris. its the vtec transition point that makes the jerk. the primary cam profile on the cams especially JUN are meant to be pushed betwen 5800 to 6800. this may sound absurb for newbies but the power hasnt died yet at the mid range. the rest of the rpm are pulled untill 9200rpm. but for street setup (mild modded) no doubt between 7800-9200 the engine is dying to be pushed which wasnt meant to rev that high either. cam gears do help with the power band but not make more power as ppl believe.
i think the toda c2 should be good in all ranges, aint that right chris? hee hee hee
I experienced the opposite. The car was jerking while cruising at high RPM because the A/F was jumping around. the reading was fluctuating like hell. when the ecu reads high vacuum column, it gave too lean something like 17-18. when the ecu reads low vacuum (just below the high vacuum column), the reading was too rich 10 - 11. and that was on the cruising part (part throttle) after VTEC is engaged somewhere between 6000 - 8000RPM.
cruising b4 VTEC and WOT were perfect.
The car was on jun 3 setup and was degreed according to the cam card. after sometime, the a/f got stable. it was like PITA!! i can see that rechipped ECUs have this problem with aftermarket cams but not all.
