I would like to customize my car fender to wide body using metal.
Is there anyone can recommend, who r very expert in customize metal bodykit with very good result?
I heard MIKE at Sunway can do the job...but like Dzul said, it will be heavy. Not sure where, heard of his name and he was the one who did this metal bodykit.
If use PU or fibre bodykit.....can be removed easier when bored with the bodykit...
If use custom sheet metal as bodykit (welded to car body), can be very tricky to remove from the car later.
Most of the time, fibre body kit requires lesser filler to cover imperfection, while custom sheet metal bodykit need more filler (also depend on sifu skill). Sometimes, if done inappropriately, the sheet metal would rust under the paintjob. In a few years time, the filler will crack and kopek from the sheet metal due to rust underneath......
Thanks for all the Sifu's replies in such a prompt time!
Ok, i will look for the USJ 1 ask for more info.
Ya, I used to change too much of fiber bodykit until I feel so tired of it crack slowly.
Planning to try metal bodykit, but true also, might get rusted after few years. Will check with the metal bodykit expert about the anti rust protection. Hopefully nothing serious happen day after la,
hehehe.
Wanna ask sumthing, is it gearbox front/rear & longshaft for evo 7,8,9 is same?
Need to know bcause mayb my car prob from this part. If confirm the problem came from this part need to buy it, so now...
