aranny2001
hi guys, im facing this problem for long. the temperature increse during sudden ramp to 5k rpm for 2~3 sec only... below shown the detail of my car and problem~
my Car: Honda Civic EG9 (SR4) 95
Engine : ME516 SOHC non vtec (D16)
radiator: just change from stock to koyorad aluminium core with bottom and top fibre cover. Just did
my radiator washed not even 3 months ago. with Denso coolant. Thermostat used to
removed when my dad use that car. Honda service centre removed it long time ago when he
also face the overheat problem. theromostat removed, problem solved
problem: 1) my car previous didn't put coolant, cause last time my dad still use to drive it, he dont
like to put coolant, reason i dont know~
2) before i use his car, i did a water jacket wash and radiator wash as well, but after 3 months while on the way from klang back to melaka at the highway, i saw my temp shoot up to maximum which shown in the cluster. luckily gasket didnt burn, i go to wash the radiator and water jacket AGAIN also did the top overhaul be since it's the old engine... time to do something on it. and change to koyorad aluminium rad.the stock radiator i can see alot of metal pieces or something like a plastic stuck at the radiator passage fin
3) one thing i found while they wash the water jacket with that machine, i can see the water is clean and only a very very few tiny black thing underneath the water. then next day i open up the radiator cap, saw some metal particle stuck inside the radiator fin! oh no!
4) to monitor my cooling system, i fit an aftermarket water temp gauge digital type (prosport). when time getting longer i can see my normal operating temp is increase slightly and i found the radiator inside for alot of metal pieces or particle inside.... gosh~ im really headache now... what the fxxx wrong with my cooling system.
dont tell me i need to wash my radiator every 5000km? :afraid::frown: where is the metal pieces coming from~ EXPERT please help me~
thx~
uptate info latest :just now i was stuck in a heavy traffic jam for 1 hour plus, as i monitor the water temp gauge, initially it shown 78 degree, then after than start increase to 80 degree, then for about another 15 minutes after, it raise to 81~82 degree, another half and hour it raise to 85~90 degree..imagine it's at night time about 8 p.m... when the traffic is smooth, i drive at speed of 90km/h it drop to 86 degree and maintain until i reach home when enter the taman, it drop to 85degree.... could it possible the water pump problem plus with the blockage of radiator?
dont tell me i need to wash my radiator every 5000km? :afraid::frown: where is the metal pieces coming from~ EXPERT please help me~thx~
