- Joined
- Jun 4, 2006
- Messages
- 2,798
- Points
- 1,683
reduces combustion temperature, inlet temperature, exhaust gas temp..thus knocking can be avoided even using RON 92.. no matter how advance the ignition timing is and how high the boost is..
easy to say, good for engines with hi CR and/or hi boost without sacrificing/worrying about what type of RON used.
am i getting this right?
U coming closer.. Not to say u needn't to worry about the RON number. U still tune as U're using pump fuel(95/97). However, u can be a little aggressive in ur ignition.
Different RON number fuel actually means different resistance towards detonation.
A few contribution that affects the premature detonations:
Air intake
Compression Ratio
RON number
Boost
Ignition timing
So, with lower intake temperature and slightly higher octane, u can reduce the detonation given the same set up/tuning. And eventually can increase the ignition timing that affects alot on the HP and torque.
