penagihdadih
thanx to correct me man!! :)
The simple maths is too simple even for kindergarten kids. U telling me u gonna spray 100cc of water into ur combustion chamber each stroke??
Bro, even 2cc/stroke will cause hydro detonation la... And, injecting water into the chamber does not reduce the cc... It only increases the capacity. Haiz...
I know how methanol works. Infact I've even deal with 4-6 cylinder engines running on pure methanol/ethanol of industrial and racing grades. That I don't need u to teach me.
When ppl are only aiming water injection to cool down the manifold temperature u're telling how good methanol is. Drain out ur fuel tank and plonk in some VP m3, then we can seat down together talking about methanol.
Haiz.....
In addition, from the way u describe and explain abt capacity, and ur 500cc-100cc theory, I have a feeling u either don't really know how engine operates or u don't really know what u are talking... Haha.. Have a nice day dude... Go do some reading.
that why i call simple math , i dont bother even to count how many cc you need to shot inside the engine.
on you statement pls tell everyone how DOES your so call capacity increase ?????
the capacity of engine is already fix .
let make another example , The 4G63 was a 1997 cc version. (85 mm bore x 88 mm stroke)
if you say by using water injection you can increase your engine capacity more then 1997cc
i can chop my head down let you sit
you cannot increase the VOLUME of the engine but using that method , what you do is you change
the density of the air but the amount that is going into the engine is still the same !
i think you cant even know the different in DENSITY and CAPACITY !
---------- Post added at 01:37 AM ---------- 6 hour anti-bump limit - Previous post was at 01:19 AM ----------
what speed2horizon telling is right.. let get this thing straight. water injection is to cooling down the mixture. y it needs to be cooled? simple! because the cooler the petrol and air mixture, the denser it become. when its denser efficiency of each cylinder improves. Water injection does not pouring a cup of water into the chamber, what it does is "misting" inside the intake manifold. Its the same at kedai mamak one when you can chill there at hot blazing afternoon n mist is spraying at you without making your shirt wet. When this applies to a hotter atmosphere such as intake manifold, the mist will quickly evaporate and atomize. By the way the chemical composition of water is hidrogen and oxygen. So oxygen can helps to burn the fuel inside the chamber. theres no such thing that it will makes parts of engine wear quicker. Y i said that? first of all because water and engine oil did not mix therefore it will not affect anything. In before, water injection does not spray directly to the oil pan and water will not even can get though to the oil pan. Take example of your iron, what happen when you spray water to it? quickly evaporates. what happen to your iron? does it build up rust? no rite? same goes in the engine department but with 'anti rust' called engine oil. so where does the theory of makes the engine parts wear quicker?
go do some reading on methanol fuel
when you using water injection , are you very sure that every tiny bit of water will be dissolve during combustion ??????? will there be case the tuner decide the tune a bit wet ???????
The extra water produced also makes the charge rather wet (similar to hydrogen/oxygen combustion engines) and with the formation of acidic products during combustion, the wearing of valves, valve seats and cylinder might be higher than with hydrocarbon burning.
so you engine oil become acid more faster because it was dilute by the acid and water
and where do you get the idea of thinking i m spraying to the oil pan ????
there are something call indirect contact , the mixture will contact with the cylinder wall
the cylinder wall will have a coating of oil , so here the 2 of them meet together.
when the piston move downward excess oil will be scrap by the piston ring and to the oil pan
so polluted oil goes into the oil pan , although the amount maybe VERY VERY LITTLE
try repeat that for 5000km see what will happen to the oil.
Sorry, typo error... It's compression ratio... Hehe...
BTW, didn't we all understood that when we talk abt water injection, it's supposed to be distilled water???
Water injection is a safe way of cooling your engine down if you have say space constraints for a large intercooler or plan to run aggressive boost/timing. It will work for NA and turbo. A water and methanol mixture will not corrode your engine parts or shorten its life. It will not affect your engine oil as well. Water + meth is for purely cooling purpose. The methanol helps the water to vaporize faster. Pure meth on the other hand is adding fuel.
The amount of water/meth being injected the engine is normally controlled and very minute. Remember injectors are rated per minute. You will probably inject for a few seconds only. The resulting mist has to be fine enought to vaporize immediately so you have a cooler charge temps and denser air. More air + cooler temps = more response.
I have logged the AFR and it does not affect it. It will however affect your intake temps and EGT to a certain extent. That's why you should not be using fuel injector where the spray pattern is not fine enought to atomize properly before going into the chambers. You run the risk of the water collecting somewhere and damage the engine. How much fuel and air your engine consume is already determined by the ECU and to some extent sensors in the car. The water/meth is used to cheat the ECU by changing the properties of the incoming air.
When you run high boost or timing and tune the car with water/meth injection. It is even better. You can set the timing, fueling and other parameters with the consideration of the cooler air. Hence ask the ECU to spray less fuel, more timing, higher boost and etc etc. But you run the risk if you run out of water. A knock sensor wiill be great if you run into this problem.
I do not change my engine oil sooner nor noticed and problem with my internal parts or cylinder walls. In fact my mech and myself is very sold on this idea. Recently we took out an engine with water/meth injection installed for many years. Think it was done in 2008. The intake track is very clean. TB, intake and intake valves were in great condition. We didnt even have to clean the valves much Even the piston has less carbon deposits. Mind you owner was using RON95 and a daily driver. This is another great properties about water/meth injection. It steam cleans your engine every time!!
Now this is with water/meth mix. I have no experience with pure meth and do not want to experience it ;)
Please do not expect high power gains with water/meth injection. It is used to suppress knock so you can have better response and more torque. You will feel a small kick when the spray start working sort of like a vtech kick. What I mentioned above is based on experience with some logging of engine parameters, local tuning results and eye witness accounts.... Happy spraying!!
just wondering who is offer best reliability and performance between AEM & Snow performance? As we know AEM produce performance part and Snow performance been water methanol injection maker.... Which brand to buy?
AEM methanol injection kit also made in taiwan....
what do you mean by the "kit" is made in Taiwan? Means they gather the parts, pack and wrap it and put it in a box, and the packaging and materials to pack is made in Taiwan?
I know for a fact the Shurflo pump used in the AEM meth kit is made in the USA..
Tell me where does Scat/Manley/K1 H-Beam connecting rod made from... Those are famous brand in US.
BTW, what's wrong made in Taiwan..?
Dear sir, you said AEM Meth Kit is made in Taiwan, I am asking you about AEM Meth Kit, not H-Beam con rods, or anything else. This topic is specifically about Water & Meth Injection, so I am asking you that only.
So, you haven't answered the question, why you say AEM Meth Kit is made in Taiwan, can you be specific?
Nothing wrong with Taiwan. Just that you state its made in Taiwan, which is not entirely true, thus I want to know.
If u ask if every single parts from Taiwan... I'll say no... But most parts are...
Nozzles, hoses, tank, seals... Not sure about pumps or any parts in the pump...
U go find out urself. I don't need to clarify myself. Believe it or not, non of my business.... Btw, if u think the internal check valve is unique, chins can do much more advance valves than this... Keep reading and go explore urself... Get a life...
Nuff said...... Chiowwwww
