sifu - anywhere got sell meth kit with install with resonable price?
other than those in sunway.
No, NA cars that are high reving, high compression will benefit also but not as much as Turbo cars. For NA its more for supressing engine knock. You may also want to use a system that varies flow so that you do not over spray.
From past experience, for a stock NA car with no engine management (ie. timing advance for injection/ignition etc) its more for cooling purposes, maybe a slight increase in air density (for stock NA car, there's usually no knocking, so can't even say knock suppression).
Without timing advance, nearly negligible gains in HP or Torque (something like 0.5%-1%). Definitely can't feel much with Butt Dyno (though sometimes it does feel like its pulling away stronger at high rpm, note I said "feel"), but on a proper dyno, you can see the minute difference :)
For NA, try mapping to TPS with a progressive controller.
Previously made a mistake of mapping to MAF, it screws up the MAF :(
Switched to TPS instead.
Set to about 3V, maxing at about 4.5V
That should make it start spraying at about 3-4k RPM with full injection at 5-6k RPM.
Tho' for NA, you can go for the smallest injector.
Question is why invest on a water/meth kit when the engine is stock? I will rather spend my money on a good ecu or a set of cams.
Originally posted by oilman
No they are no good.
Have a read.
General Remarks on Chlorinated Additives.
A number of ‘add-on’...
