fuel regulator
fstr
7,935
954
Sahara Desert
whats best pressure for 1.6 stock mivec...?? opinion pls..
stock for mivec shud be 35-42 psi.
4g91 stock shud be 28-32 psi.
4g93 stock shud be 34 to 38.
that is just for guidance and it shud compensate with wat u have done to ur internals and ur add-ons.
wira_tak_laju
4,184
GT auto - usaid higher thn 40 psi ,below 46psi..is this idle or WOT??..whts ur recomended set up then?? idle and WOT..need opinion as i m playing around with this unit to see which is best power..he he tarak bujet dyno le
kelv!n
218
got a question here... wats the diff between the big and small sard fuel regulator? and wat shud be the ideal pressure for 4g18?
GT_AUTO
3,503
71
K.Trg
www.facebook.com
same as the mention above.sard big can withstand higher press.ideal
for force induction engine.
4ndr3wt1n
6
Sifoo,
Been hearing alot of this f/reg. Just 1 'q'... do carb engine uses 1 too?? or is it juz for fuel injection?
Rgds
Andrew
kelv!n
218
so which means since that my ride is NA is ideal that i get the small and not the bigger one rite?
Hi guys,
I own a CRZ and at the bottom of the front windshield, there a part that always collect water.
And I am not sure if its due to rain water or tap water collecting there. Here's a pic.
Any way i can try to remove it?
Ive tried glass cleaner and elbow grease, but doesnt seem to work at all. Am afraid it might be permenantly marked.
Thanks
