fuel regulator
fstr
7,935
954
Sahara Desert
whats best pressure for 1.6 stock mivec...?? opinion pls..
stock for mivec shud be 35-42 psi.
4g91 stock shud be 28-32 psi.
4g93 stock shud be 34 to 38.
that is just for guidance and it shud compensate with wat u have done to ur internals and ur add-ons.
wira_tak_laju
4,184
GT auto - usaid higher thn 40 psi ,below 46psi..is this idle or WOT??..whts ur recomended set up then?? idle and WOT..need opinion as i m playing around with this unit to see which is best power..he he tarak bujet dyno le
kelv!n
218
got a question here... wats the diff between the big and small sard fuel regulator? and wat shud be the ideal pressure for 4g18?
GT_AUTO
3,503
71
K.Trg
www.facebook.com
same as the mention above.sard big can withstand higher press.ideal
for force induction engine.
4ndr3wt1n
6
Sifoo,
Been hearing alot of this f/reg. Just 1 'q'... do carb engine uses 1 too?? or is it juz for fuel injection?
Rgds
Andrew
kelv!n
218
so which means since that my ride is NA is ideal that i get the small and not the bigger one rite?
There’s no doubt about it, The Jungle Book is one of those stories that is just simply timeless. It has everything you could possibly want: lovable characters, singable songs, and a dancing primate. But who knew that a bunch of jungle animals and a man-cub named Mowgli would teach us so many life lessons? Not us. But lessons we did learn. Ones like these:
A 3 door...
