4g15 carb to fuel injection
klutch
15
typo loh..4g15 actually :biggrin:
sori bro..
nway, how to improve the power aa?
chris_ch3w
407
4
sori bro..
hi-cam
1.6 stroker kit
adj cam pulley
skim off ur flywheel
n bla bla...
many ways to increase power for ur 4g15...if BOT, possible get 120hp...so do ur research bro..u will be more satisfied wif the knowlegde u get at the end of the day...cheers :smokin:
tofu_manic
1,342
91
5,148
hi-cam
1.6 stroker kit
adj cam pulley
n bla bla...
play 4g15 n/a also can get 140 hp....0-100 below 8 secs...
craziqbal, for the following mods:
hi-cam = rm 12xx
1.6 stroker kit = rm 10xx to 15xx, if 4g13 need 4g15 block, spend more $$$$, total overhaul, more $$$
adj cam pulley = rm 2xx
skim off ur flywheel = rm 1xx including balancing
craziqbal
111
cool, thanks tofu_manic...will definitely think about it as it is within my budget..
GT_AUTO
3,503
71
1,648
K.Trg
www.facebook.com
hi-cam = rm 12xx
is this taken from waja?
highbeam
12
wiring, ecu, intake manifold, throttle body, distributor, fuel pump, fuel filter, fuel rail, sensors...
estimate budget needed around rm800 (parts alone) + rm500 (installation)... jz prepare around 1.5k to 2k jz incase other stuff needed to be changed as well...
change head,head gasket,pully too
tofu_manic
1,342
91
5,148
wats the diff between efi head/ pulley and the carburetted version?
i have some information from turbo sifus out there.
1. i need some explanation for turbo different of cars like ford ranger, toyota hilux and other with cars like evos,skyline gtr and others.......
2. can sifu here explain me about the different......
3. i also would like to know how strong does the turbo for that twin cabin compare to those powerful cars........which one is stronger/powerful?
4. can the turbo in twin cabin be as powerful as those evos car?
5. if i want to make the turbo...
