cylinder head dont need to change... u only need to seal up the AC pump socket with any metal plate... fuel injection needs electric fuel pump....change head,head gasket,pully too
intake manifold head studs for fuel injection is longer.... and fuel injection cylinder head dont have socket for ac pump (mechanical fuel pump)wats the diff between efi head/ pulley and the carburetted version?
so carbie & injection dashboard not same la u say..Dear skywalker...
sure can use old dashboard wan... what im trying to say is wira injec. comes in 2 wiring.. 1 is for ur engine injection system and the other is for the tuning purpose... For injection model dashbord, there is few extra wirings compare to carbie model dashboard( The wiring for the engine check... This wiring is connected from the ecu to the wirings in the dashbord for tuning and light for the engine check...
If u want to stick to ur exsisting dashboard, is not a problem... u can either simply change ur speedometer or add 1 lamp in ur exsisting speedometer and pull 1 cable out straight to ur ecu.. try to find light green+red wire at ur ecu wiring ( there are onli 2 of those.. one is bit darker green)
And for the tuning.... well.. ive been scearhing all over the net and wiremans all around KL and none can do the wirings...have olso they say tak berani la boss.. and i need to get the socket for tuning too
so dear skywalker.. it is just a prevention purpose onli... the tuning is only for checking the engine onli.. or u can always do standard try and error if the car gets F**ked up later... (if u dont have these cable...) unless u are a good mechanic..
if u dont know DONT REPLY and dont simply get other poeple to get cofused ok...
sorry in advance
Not the same interm of wiring la... If can find a good wireman then can use ur old dashboard.. if u can get the socket and try to copy the wirings from other inj models wira.. Yes, if complete it should come wif the tuning socket.. i think better stick to carbie.. coz no significant difference in performance compare to 4G15 injection.. even FC oso not much diff. If wan to change to inj. better go for 4G91..(if looking for 1.5 lah..) quite old but very reliable mitsu engine... plus u get a nice dashboard wif digital aircond too..so carbie & injection dashboard not same la u say..
wiring cant be dismantle from dashboard lor like this..
not worthy lor half cut selling dashboard kosong..
i tot dashboard all same..
only injection & carb wiring also meter not same..
if complete injection wiring they should be with tuning socket..
if dont have sure not complete..
i dont know lo bout this..
that why want to ask u..
dont marah ye..
saye budak baru belajar..
tumpang lalu ye sifu skywalker..
bro,Dear skywalker...
sorry in advance
so dashboard & wiring differ le between injection & carb..Not the same interm of wiring la... If can find a good wireman then can use ur old dashboard.. if u can get the socket and try to copy the wirings from other inj models wira.. Yes, if complete it should come wif the tuning socket.. i think better stick to carbie.. coz no significant difference in performance compare to 4G15 injection.. even FC oso not much diff. If wan to change to inj. better go for 4G91..(if looking for 1.5 lah..) quite old but very reliable mitsu engine... plus u get a nice dashboard wif digital aircond too..
Btw, the dashboard at chop shop does not come wif the wiring.. only the kosong dashboard..
Just for info, if wan to install these wirings, it will cost u around 1.8k at Proton service center..Just for the wirings tau.. New complete original wiring..
eh dint notice this....how come carb save petrol at high speed as compared to efi?better u stick wit carb..
that of course if u r a racer..
carb save petrol on high speed..
but still lack on pick up..
good info, but chill on the attitude bossDear skywalker...
sorry in advance
that y i want to ask this highlander guy..wat happened??... wiring dashboard ahh??... ooo... sorry la i noob mah.... i didnt know the wiring are built into the dashboard where u need to change the whole dashboard jz for the check engine light....
