4g15 carb to fuel injection
klutch
15
typo loh..4g15 actually :biggrin:
sori bro..
nway, how to improve the power aa?
chris_ch3w
407
4
sori bro..
hi-cam
1.6 stroker kit
adj cam pulley
skim off ur flywheel
n bla bla...
many ways to increase power for ur 4g15...if BOT, possible get 120hp...so do ur research bro..u will be more satisfied wif the knowlegde u get at the end of the day...cheers :smokin:
tofu_manic
1,342
91
5,148
hi-cam
1.6 stroker kit
adj cam pulley
n bla bla...
play 4g15 n/a also can get 140 hp....0-100 below 8 secs...
craziqbal, for the following mods:
hi-cam = rm 12xx
1.6 stroker kit = rm 10xx to 15xx, if 4g13 need 4g15 block, spend more $$$$, total overhaul, more $$$
adj cam pulley = rm 2xx
skim off ur flywheel = rm 1xx including balancing
craziqbal
111
cool, thanks tofu_manic...will definitely think about it as it is within my budget..
GT_AUTO
3,503
71
1,648
K.Trg
www.facebook.com
hi-cam = rm 12xx
is this taken from waja?
highbeam
12
wiring, ecu, intake manifold, throttle body, distributor, fuel pump, fuel filter, fuel rail, sensors...
estimate budget needed around rm800 (parts alone) + rm500 (installation)... jz prepare around 1.5k to 2k jz incase other stuff needed to be changed as well...
change head,head gasket,pully too
tofu_manic
1,342
91
5,148
wats the diff between efi head/ pulley and the carburetted version?
I got a Carvox CX-990 ( aka Radiostar King-Eagle ) 2 way lcd alarm a 2 month ago. I got it installed and it was working fine. Now it got cold the remote starter will not start. It only starts when the engine is warm. What happens wile the engine is cold is: it will crank for a second and shutoff and siren goes off at that time.
I got the system on ebay and got it professionally installed all together $300+
I took it back to the shop they checked and rechecked all connections for 2hr...
