4g15 carb to fuel injection
klutch
15
typo loh..4g15 actually :biggrin:
sori bro..
nway, how to improve the power aa?
chris_ch3w
407
sori bro..
hi-cam
1.6 stroker kit
adj cam pulley
skim off ur flywheel
n bla bla...
many ways to increase power for ur 4g15...if BOT, possible get 120hp...so do ur research bro..u will be more satisfied wif the knowlegde u get at the end of the day...cheers :smokin:
tofu_manic
1,342
91
hi-cam
1.6 stroker kit
adj cam pulley
n bla bla...
play 4g15 n/a also can get 140 hp....0-100 below 8 secs...
craziqbal, for the following mods:
hi-cam = rm 12xx
1.6 stroker kit = rm 10xx to 15xx, if 4g13 need 4g15 block, spend more $$$$, total overhaul, more $$$
adj cam pulley = rm 2xx
skim off ur flywheel = rm 1xx including balancing
craziqbal
111
cool, thanks tofu_manic...will definitely think about it as it is within my budget..
GT_AUTO
3,503
71
K.Trg
www.facebook.com
hi-cam = rm 12xx
is this taken from waja?
highbeam
12
wiring, ecu, intake manifold, throttle body, distributor, fuel pump, fuel filter, fuel rail, sensors...
estimate budget needed around rm800 (parts alone) + rm500 (installation)... jz prepare around 1.5k to 2k jz incase other stuff needed to be changed as well...
change head,head gasket,pully too
tofu_manic
1,342
91
wats the diff between efi head/ pulley and the carburetted version?
Hello sifu's,
I have a question here. I was informed that removing balance shaft lightens the engine. No doubt the vibration increases but does the performance increase too ?
Is there any side effect ? Can we get the timing right or not ?
There is supposed to be 2 balance shafts ? can we remove both ?
Another question is regarding injectors. Instead of adding additional injectors can we use the RX7 injectors for 4G63T. What are the difference. RX7 is supposed to be 1.3 rotary...
