Many doubted the functionality of an OCT and today i am going to show you the proof that an OCT does work.
NOthing to do, so took out the OCT and.. hey! It's heavy.. Shake it a little .. liquid inside apparently!
It works..
So i drained the oil out.. it captured about 100 ml of the PCV blow-by in extremely dark color: http://drexchan.fotopic.net/p23967874.html
Accidentally spilled it and you can see how dirty it is: http://drexchan.fotopic.net/p23967883.html
So, i washed the OCT using petrol. Just pour some petrol through the hose and do a "milk shake"... this is what i got: http://drexchan.fotopic.net/p23967886.html
Discovered some leakage from one of the hole that was supposed to be sealed. Remove the seal and redo a silicone oil seal.
Then reinstalled it back and started the engine... seems like the idling now became irradic (from the vacuum gauge reading)..
Must be something wrong in the previous setting (remember the leakage?) that the ECU has adapted to.
So, no worries, reset the ECU and make sure everything is working fine, re-adapt the throttle position and everything went so smooth.
So, OCT works. Just clean it once a while..
It works..
