[WTA] ECU Terms
CasperR
Aug 8, 2010
37
508
Wanting to clear my confusion a bit. ECU controls the ignition, rev limit, transient fueling etc. So a better ECU allow more space for a greater mods like horsepower, torque?
And also, what's the difference between ECU reflashing, mapping, tuning etc?
Been reading some GTR/GTT owners' blog and referring back to some reading sources, but they are not detail enough regarding the difference between mapping, reflash etc. Anyone mind to give me a guide? Thanks in advance :biggrin:
V-Spec
1,861
170
5,163
Reflashing/remapping refers to re-writing over the stock ECU.
If all else being equal the better standalone would have more mapping points/grid/resolution. Eg. HKS F-Con has 32X32 versus Power FC's 20X20
cmng
3,289
72
Later you want to ask about PWM , Input outPut, Map correction factor type
bla bla bla
the more you read the more headache you all
CasperR
37
508
EJ, so does that means that after reflashing/remapping, for the next steps people usually tune the ECU to suit the drivers purpose?
And if people don't want to reflash/remap, people just go straight for a aftermarket ECU right? (if cash is not an issue of course) :hmmmm:
cmng,
Shall leave that alone at the moment. One step at a time. Learning process :sleep:
Nismo S-Tune,
Agree with that equation :biggrin:
V-Spec
1,861
170
5,163
CasperR (the friendly ghost? :biggrin:), reflashing involves overwriting the factory map and loading a new map in - either pre-tuned for basic stuffs like new intake, exhaust, higher boost, ignition timing, a/f, speed cut, etc....
OR it can be re-tuned for that particular car.
Yes, if budget permits, you can opt for full stand alone aftermarket ECU.
The Marketplace Top Posts
If your thoughts on the smallest car in the world happens to be the Peel P50, there's something smaller, although, not made to carry any passengers. The DENSO Micro-Car is a miniature version of Toyota's first passenger car, the 1936 Model AA sedan and it is 1/1000 of the original car size.
The micro-car comes with complete...
