- Joined
- Feb 20, 2006
- Messages
- 4,078
- Points
- 1,648
Autronic ?
Did you need to purchase the cas sensor separately ?
Yes, basically you need to purchase the cas disk which last I remembered, doesn't cost much. Basically, it a flat piece of steel or copper with some hole on it. If you can get the template, you can probably make one yourself.
What I have not gotten much out of some people using motec or autronic are, how do they wire the tps out for the attesa. Apparently, the attesa tps signal reads a certain voltage range (something like 0-3.5V) which has a built in module within the oem ecu. Either one has to purchase a separate tps module for the attesa from ecu manufacturer, or built one.
I may be scraping the project to have Autronic due to limited support and knowledge from techs over where I am at. That's why it is used as a paper-weight now ...
with me and AE111-SEG joining in the fun..
