Unbalance power from amp
MrBinn
Kuching, Sarawak
Hi guys,
Recently, my setup is giving me some problem. I am using an amp to power up my front componenet speaker. The amp is about 1 and half years old. Recently, my amp gives out unbalanced power at times. Meaning my left side speaker is much louder than my right speaker. I tried swapping the left and right connection and confirmed the problem is with my amp. Anybody experienced this before? By the way, the unbalanced power occur at times only and sometimes its ok. please advise
could it be the signal wire to the amp from the HU something wrong instead? U swapped the output to speakers only rite...? Try swapping the input and see....
Well, if is a cap ayam, then I will say is the amp problem, but what our friend is true, check all the connections first before make a conclusion. Hope this will help.
Write your reply...
