Turbo Kong
Originally posted by dkoo@Nov 18 2004, 12:14
haih.. have to revise again my plan.. all new information keep on coming out.. so many factor to think on this small siput.. aiyo... :blink:
woo...TD05H small siput :) Like that muz be like SaGa_TuRbO edi put TD06-20G :) That one confirm big siput lah :D Go dkoo GO~!! :lol:
Regards;
if there is hairline cracks , u have to weld it la , no choice , as for my spare 16G turbine , it has a small crack at the wastegate flapper , its a tiny crack so u have to look carefully , most cracks aren't visible , some cracks are inside the turbine housing and not outside , the only way to find out is to open up the compressor and turbine .
Originally posted by SaGa TuRBo@Nov 18 2004, 13:27
Alex,dun kacau people's thread..Shhooo Shhhhioooooo
:lol: Wei boss, u also hijack other ppl's thread la :P
Ok back to main topic, turbo kong edi wat to do? Either change to a bigger turbine TD06-20G like SaGa_TuRbO or service the old one...
Hhmm, din check my turbine n exhaust housing for cracks when I bought it. Hopefully it's in good condition... :huh: :unsure:
Regards;
dkoo, nah...
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&category=33742&item=2474262110&rd=1&ssPageName=WD1V
Very tempted <_< ....
thanks for the hints vesty...
oh vesty.. the crack can weld 1 izzit?? i tot it crack into half already.. ;)
then ok lah... poor style playing car is like this lah..
for me i just get a used 1.. then crack then weld.. :lol:
oh... rupa rupanya the u put in td06 20g....
thanks alex for the info.... :lol:
the rest maybe i won beleive about adrian.. but alex told about adrian.. 100% correct 1...
wow...06 20g ah.. very fast man.. wow wow wow.. 400hp monster on the way izzit??
aiyo.. my project 250hp only... :lol:
i'm slow bai... :P
alucard, thanks for the info.. but expensive bai... :lol:
but it look chun..
actually ah tong got a 6cm housing td04hl 18g.. going for 1.2k if i not wrong.
he told me is for 300hp n more...
how is this recon siput compare to a used td05h 14b??
both also 6cm housing..
vesty or anyother sifu plz help abit..
dkoo koo bird ,
TDO5H can go up to 300 to 350hp , 16G small & big can go up to 400hp , but aready maxing out . if you want to target 300hp , its not about the turbo alone , u need other mods too .
here is some guide :
1G = 4G63 similiar to vr4 7.8:1 comp
2G = 4G63 similiar to evo 8.5:1 comp
Stage 1 mods estimated 300hp :
Step 1
Intake Pipe and Filter
A performance intake filter will help throttle response and help all future mods achieve maximum performance. A hard intake pipe will also improve air flow over the factory piece.
Step 2
Aftermarket Boost Gauge
The stock boost gauge is simply not accurate. To avoid severe engine damage when increasing boost levels, an aftermarket unit is mandatory.
Step 3
Boost Controller
In order to raise boost levels, you'll need a boost controller. Whether it be a manual or electronic unit will depend on your budget.
Step 4
Cat-back Exhaust System
A 2.5" or 3", high flow exhaust system is needed to gain more power. The factory exhuast is very restrictive and hurts power
Step 5
High Flow Downpipe
The factory downpipe is very restrictive and should be replaced with a larger, better flowing unit. For Stage 1, a 2.5" downpipe will do. If future plans involve 500+ horsepower, consider a 3" downpipe.
Step 6
Exhaust Manifold
The exhaust manifold on 1G DSMs are notorious for cracking and leaking. The solution is to replace it with a ported factory 95-99 exhaust manifold. If you're planning on going with a full Garrett turbo, you'll need a special manifold.
Step 7
O2 Sensor Housing
The downpipe bolts up to a 90 degree elbow called the O2 Sensor Housing. This is the last restriction in the exhaust system. The stock unit can be ported out, or you can simply buy a better flowing unit.
Step 8
Fuel Pump
The stock fuel pump will not be able to supply the needed fuel for long - especially if the boost level is raised. A high flow unit will be needed. It's also a good idea to re-wire the fuel pump for consistent fuel pressure
Step 9
Intercooler Piping
The rubber intercooler piping should be replaced with better flowing solid pipes. Some replacements will come with a larger throttle body elbow (which is needed also). The turbo outlet elbow should be swapped out for a larger unit as well. Please note that if a Stage 2 setup is in the plans, this upgrade may not be necessary as the intercooler piping will likely be routed differently.
Step 10
Performance Clutch
With more power on tap, the stock clutch probably won't last that long. It will start to slip, especially in the higher gears. This means it's time for a high performance clutch.
Please Note: 1G automatic transmission cars have a smaller stock turbo (the Mitsubishi 13G) than the 5-speed cars and will require a turbo upgrade in order to achieve Stage 1 performance levels.
Stage 2 estimated 400hp :
Step 1
Logging Software
Before you can safely begin making fuel adjustments, you'll need to know what's going on inside the engine. Logging software will give you this data and will help you decide what fuel delivery changes are needed, how much change is needed, and at what RPM point. Though datalogging is mainly for tuning, it's also a critical tool to prevent major engine damage as well.
Step 2
Warning Meters
Along with a datalogging solution, you'll want some gauges to help monitor the engine. While dataloggers allow you to analyze data after doing some test runs, guages are easier to read while driving. An EGT (exhaust gas temperature) gauge and probe will allow you to monitor the exhaust temperature exiting the engine. Extremely high temps generally translate into a lean condition and can be catastrophic. You can also go with a Wideband O2 system that will allow you to monitor the air/fuel ration of your car while driving. This will tell you exactly how rich or how lean the car is running, allowing you to adjust the fuel curve
Step 3
Fuel Controller/Engine Management
In order to control the flow of fuel of the larger injectors, you'll need some form of a fuel management system. This can be achieved by a piggy-back style computer which still uses the factory MAS, or using a stand alone fuel system which replaces the MAS. This will be the key component in your system. If you choose the piggy-back route, we also suggest that you look into upgrading to an EPROM ECU if your car isn't equipped with one. This allows you to get an aftermarket EPROM chip that can be programmed to work with the fuel modifications you have done.
Step 4
Fuel Injector Upgrade
To supply the amount of fuel necessary for Stage 2, the stock fuel injectors will need to be replaced with higher flowing units. The larger the turbo you plan on upgrading to, the larger the injectors you'll likely need.
Step 5
http://www.dsmtuners.com/parts/images/agp-l2r.jpg
Turbo Upgrade
At this point, the stock 14b turbo is running at it's max. In order to increase boost, a larger turbo is necessary. You'll need something larger than a 16G or 18G in order to achieve power levels above the 375hp mark. A Mitsubishi 20G, a Mitsu-Garrett hybrid, or a full Garrett setup will be needed for higher horsepower levels. Keep in mind however, that any non-Mitsu turbo will require a special exhaust manifold, external wastegate and O2 sensor housing.
Once you've completed these mods, and only then will you have enough knowledge of how these cars handle power to go further. You should now know how tricky the art of tuning can be, and you're likely well versed in spending money on parts and repairs. It is possible to get over 600 horsepower out of the 4G63 engine, but it will require some digging into the motor to add some high performance internals. Be prepared to spend some big money.
Try to keep in mind that many repairs will need to be made when you start making these power levels due to the simple fact that things tend to break. Plan for it, especially if your car has high mileage.
Info Taken From DSM Tuners
huh?? 300hp jsut so little mod??
what i planing now is the material on 400hp stage ler..
vesty ya..
let say ya..
i got a proper clutch, vr4 injector, e3 fuel pump, fuel regulaotor, 2.5downpiping + straight 2.5 exault piping to muflur, proper braking system, vr4 intercooler, with td05h single fin boost at 0.9bar + mainkotek tune properly by johua... can i get 250hp?
i just wanna go for 0.9bar.. coz i dun have metal gasket..
or need bigger turbine for 0.9bar on my 1.6engine in this kind of setup??
Fui yoh,vesty you have done till which stage ahh??? :)
Dkoo,buy my turbine la...I sell you cheap cheap.... :)
ur turbine still in my consideration.. :lol:
but now i will wholely replan my budget and my project.. since so many extra information and factors i have know..
haih.. confusing.. have to find joshua talk talk about the turbine and tuning see how..
Write your reply...
