Your air + fuel ("AF") mix was incorrect/ not stable to your MMC ECU AF mapping since u changed to bigger throttle, hence u felt that are underpowered. You will feel more air sucked in but the car was so-call loosing torque. I guess like this case, u are losing mid-range + top end torque a lot. Somemore u will also notice that your FC a bit high and dark smoke labelled at the exhaust tail.
U should get yourself a VAFC or equivalent to retune your AF ratio and match with the MMC ECU apatite. This would turn-back your performance to 99% normal after that. Make sure to get a correct tuner to do it as u are running on after market ECU!
