The 4agze Forum
sifu2,
what resipi do we need to make 101 4agze can boost >1bar ...n...rev all the way smooth up to 9k rpm..? pls list down here...tq
---------- Post added at 11:15 PM ---------- 6 hour anti-bump limit - Previous post was at 11:11 PM ----------
i read te whole topic here,...just cant gather the info that those otai give.....as i remember....
ecu, oversize pulley (crank n charger), hicam, front mount ic, abv, .....
been serching n ask ard,....otai charger said...if change small pulley.....charger will not tahan....3-4 month KONG.....
they recommend to install rotrex supercharger.....can hi rev......BUT.....charger ....abit makan minyak....
Small pulley? Sc12 kong? Why small pulley? More boost? If not wasting time n money la change small pulley. Dun just listen n spread rumours if u dun test it. It will make ppl confuse.
My 2 cents.
Sent from my C6603 using Tapatalk 2
the other mechanic in kajang gold me.....if u transplant 101 charger n use standalone ecu.....if always hi rev......charger easy kong,.....n.....the other one mechanic also using charger......according to a fren know him....said 10 yrs change 3 charger......
will it b this way ?
So, it is not pulley issue. It is because hi rev habit. Hi rev till 9k rpm? If u hi rev all the way, no matter what charger unit will last longer. It is not about standalone la bro. It is heavy right foot syndrome.
Other sc user use more than 10 years also ok. Dun jump to conclusion too fast.
4AGZE...any solutions on why this engine tends to stall every cold start?
Please advise...need to control the throttle for few seconds every cold start in order to stabilize the idle....sad2.:hmmmm::hmmmm::hmmmm:
Meaning after you start your engine in a few seconds, then you floor the pedal?
Hey I'm quite new to the whole 4agze SC scene and I have quite a few questions.
First of all, what model of the 4agze has the alternator mounted and the bottom?
As it was bought second hand, what should I look out for and maintain to keep the engine running healthy?
What oils and other lubricants needed for a SC engine?
Sorry I'm new to the car scene, just got my first car.... Any sifu can teach me the ways?
i dun catch your 1st question.
maintain your right foot when aircond is on. if want to floor the pedal, turn off the aircond.
take care the driveshaft (try to keep a spare) and rechip the ecu. also keep spare for aircond compressor. use original superchager oil (toyota brand). if want to use aircond oil, change regularly.
any oil can fit except fully syn. others oil u must try which one suits your engine.
others sifu can add more info. im just newbie.
Is there any other way to driving the car with aircond on without maintaining my right foot? I heard from a friend that they install something called a vacuum to bring the revs a lil higher so the car doesn't stall?
The car stall at higher rev? When u turn on a/c, the compressor magnet will engage. It has nothung to do with stalling the engine. You can floor the pedal all the way bro whether the a/c is on or not. But the a/c compressor lifetime will be short and prune to damage.
Hello everyone, I once again have a question...
What would be the recommended mods to increase hp for the 4agze engine besides getting a bigger sc like the sc14?
mods to increase power of sc engine..bro so many things can do.. depends on how deep are your pockets.
Well I plan on doing the mods one by one with funding from my part-time jobs as I'm still studying.. So a list of what's to be done would be a great help!
first determine weather your engine is healthy before deciding to bump the power.. shaky rods and added power = rebuild.. lol.. if all engine healthy then biggest bang for your buck is to turbo it. if you decide to still keep the sc instead a full standalone ecu will help. but dun expect huge gains. set a goal first then we can work from there.
