..ok ok boss...what is a cup of tea..come we go nasik lemak ler.. ekekekek..but then
..when u come here..ppl wait..u go airport ler...:hmmmm:
..heard got HM..thats why ler..
..hehehehehe
...never mind..lain kali ada....
..wahhh pecah rahsia!!!! WAKAKAKAKAKA
..ppsstttt..ppssttt!!!!Im a beginner in this field, only started to play engine 2 months ago.
i drive an AE100, transplanted 4AGZE from Trueno. So far, what i did;
Change bigger pulley - boost to 0.8
K&N Air Filter
Iridium Spark Plugs
ELF Fully Syntetic Oil
VR4 front mounted intercooler with steel pipes
What else do i have to do to increase boost? Thanks to all sifu
I'm no sifu but from what I learned from my friend's SC, you should upgrade your fuel pump, dump in a fuel regulator & get at least a piggyback to set your fueling right before your engine detonates from the high boost.
PS: I think the top mount intercooler should have less lag than the front mount. The way I see it, 0.8 bar of boost does not require a bigger intercooler; just yet.
upgrade fuel pump, means add a fuel regulator? which is good? im using the fuel pump from my ori AE100
so the top mount intercooler is still ok?
sorry, but whats a piggyback? im noob at this.
my standard 4agze ECU is modified. no rpm cut
i just biught a VR4 IC, i guess i wont be needing it now
shud i change my fuel pump to the 4agze fuel pump?
if i add in a fuel regulator, can i control the usage of fuel? becoz at this moment, rm10 will only go 30KM. is that normal? rm30 can go 100KM
haha is ok bro, the one like ur fren we used to called it "twin charger"
yup the theory almost the same, means u did help our member
by the way, ur fren moded to twin charger is for drag race ah? how's the power? u got the spec ah?
