or on top of the block....
c00lric said:Hi Kunyit,
I'm facing the same prob as u hav faced b4. How did u notice that ur head engine was the source of the prob?
c00lric said:yeah. da top block is ur engine head. Hehehe. Thnx hattech. still a noob ere.
kuNyit said:secret! hahahahaaaa...
i knew coz i have a lot of xperiences before for this kind of overheating issue.. another thing you need to replace is your engine gasket. Think this is best time you need to replace with new one!!
but if still happend again after you replace it. It could be one of the block screw had beed loosen. It better ask your mech to check as well! Coz i have seen 1 fella faced this which fixed by my mech.
raybakh said:mine is another case,
last time got overheat,so my mech check and check and found out that the thermostat is faulty. So, he throw the the thermostat out and now the car is running w/o thermostat. It keep the engine cooler as water are running the block everytime unlike using thermostat when only temp rise does the thermostat give way for water to run around. Never had my temp needle more than half even during jam.
