- Joined
- Aug 3, 2004
- Messages
- 612
- Points
- 3,016
turbonetics...u boost 1.9 bar ur engine tak pecah ah...wat piston and conrod u using???
ftzone said:Joeker bro.. u sure AVCR nor ext. Wastegate will not solve my problem? thats sad man... the gasket should be standard mm for the 4G93P engine. Changing the gasket again will cost me a bomb. I'm going to die.
turbonetics said:i'm using blitz dual timer...means im using digital boost meter...yes...1.9 was the peak...some ppl said tht timer wasnt accurate...i did ask some of my frens...they said it is accurate..after the peak...boost starting to drop till 1.5 -1.7
Itab said:bro,standard 4G93P NOT using metal gasket leh.correct me if i'm wrong.coz u mentioned tht u using metal gasket,tht's not standard 4G93P gasket leh.
ori mitsu 4G93 1.5mm metal gasket i have it for sale in the sales section la,check out my thread lo :) price is RM250 brand new
a fren of me once informed me tht tong turbo selling actuators for RM50 only.go check it out la
cheers
keong_GSR said:1.9bar on stock GSR? cannot be lar if stock internal...1.5bar with enough fuel delivery & TD05H pun blow liao...the conrods patah! i used to see my fren GSR with 2.0bar but with AFC,B8 piston... he boost 2.2bar just want to try with VR4 HALTECH,kaboom!!! another fren of mine with 2.5bar the max that i have seen so far in my life...the levin turbo...but with microtech lar...n spend
nearly 30k modification...low boost 2.0bar,if less then that,the car jerking like hell since too rich... :)
ftzone said:Original 4G93P of coz not using metal la.. what i meant is the thickness of the gasket is the same. Now I'm using metal gasket (same thickness with the 4G93P) Me also selling ler.. RM399 with complete valve seals, cam cover gasket, spark plug ring, exhaust manifold gasket and e.t.c what i felt was... faster pickup. Yours RM250 with those things or not? If yes..it's a very good deal =)
