Need scavenge pump for turbo oil return > HELP !!!
ravingill
Hye guys , i recently purchased a Bmw e34 with bolt on turbo , the car is fine just that it blows blue smoke, when took it for a check i found out that the turbo oil return is not same level as the oil sump because the turbo sits lower then the oil sump, therefore the turbo/exhaust seal leaks and it burns oil in the exhaust piping giving me blue smoke.
Solution is to fix a scavenge pump (oil pump) to the turbo oil return line so the oil will be pushed back into the oil sump without damaging my turbo/exhaust oil seal. The problem is where do i find such a pump , i have checked everywhere but i cant find 1, i have just serviced the turbo and all , but i need to fix the scavenge pump to the oil return pipe.
Any help will be greatly appreciated guys, thx so much
The scavenge pump is something like this >>> http://www.scavengepump.com/
